Modular V10 (6.8l)
bolt pattern question
Old Dec 21, 2010 | 02:50 PM
matt777's Avatar
matt777
so heres the deal i got a 99 f250 and a cousin of mine wants to sell me the wheels and tires off of his 2011 f250 and i want to know if the 8 lug bolt pattern is the same so i can know if they will fit.
Old Dec 21, 2010 | 03:35 PM
scraprat's Avatar
scraprat
Top Answer: 5
I believe they where 16" maybe 17" wheels on the '99' and the '11' starts at 17'' wheels and the brakes are bigger ('08'+ years). They will not fit.
Old Dec 21, 2010 | 04:14 PM
matt777's Avatar
matt777
My 99s r 16s and the ones I want are 17s so that does make sense thanks
Old Dec 21, 2010 | 04:53 PM
matt777's Avatar
matt777
Just a thought if the brakes r bigger wouldn't that mean that there's more room for them to fit or will the rim just not line up right
Old Dec 21, 2010 | 08:46 PM
ol'yeller's Avatar
ol'yeller
As long as you're dealing with your cousin, couldn't you arrange a meeting where you try on the new wheels on your truck? That's the only way to be sure. Make sure you try it on the front and with the truck off the jack. I'm pretty sure my factory rims are 17". I'll check in the daylight and correct this post if needed tomorrow.
Old Dec 22, 2010 | 01:09 AM
Mr Hanky's Avatar
Mr Hanky
From everything I have read and seen you can put the 05 & newer wheels on your vehicle they will just stick out a little further (not much & actually looks better) than the ones you currently have as they have a negative offset...the larger diameter wheel will only give you more room between the calipers and rotors and will not be a hinderence. They problem comes when trying to put a pre 05 wheel on a 99-04.
Old Dec 22, 2010 | 05:01 AM
scraprat's Avatar
scraprat
Top Answer: 5
This is from a quick Google search.
Ford Bolt/Lug Pattern Guide Reference Chart RimExpert.com
Old Dec 22, 2010 | 08:35 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
They will fit, but the backspacing is different, so they will sit IN further on the truck and make it look funny.
Old Dec 22, 2010 | 12:31 PM
mwsF250's Avatar
mwsF250
That is my understanding as well. Identical bolt pattern, but more backspacing on later models. If you don't haul or tow heavy loads and understand and accept the risks, can use spacers to move them back out.
Old Dec 22, 2010 | 08:32 PM
fuelman's Avatar
fuelman
The 05 and newer have a deeper backspacing which does mean they set INWARD more. This is because in 05 they went to coilspring front suspension allowing the deeper placement. What this did is allow for a shorter turning radious(like dodges). Spacers are available, 1inch required to match original placement. Without spacers the tires will hit the leaf springs when turning.
