Need help
Old Dec 15, 2010 | 10:37 AM
my03F250's Avatar
my03F250
Need help
Need some assistance....Have an 03 5.4 w/137K miles. When I first start it (after sitting for a few hours) I get a knock on the right side. The knock pretty much goes away after a minute of running although you can still hear it faintly if parked between two vehicles or getting underneath and listening carefully. I am not the original owner but the noise was not there or at least evident when I first purchased the truck. I do my own maintenance and keep up with oil changes every 3-4 months. I do not put many miles on it each month. I only use synthetic oil with the motorcraft filter. I have, in the past, pulled the oil filter apart checking for excessive metal and have even run a magnet through the drained oil for the same reason as the filter with nothing. Is the knock something I should be concerned with? I do not do any hauling and do not abuse the vehicle. I still get around the same fuel mileage (10-12 mpg in the city) and all fluids remain at the approriate levels with exception of about 1/2 qts oil being lost between oil changes. Any advise would be greatly appreciated.
Old Dec 15, 2010 | 11:07 AM
powerstroke72's Avatar
powerstroke72
Thread moved to Modular V8 (4.6L, 5.4L) forum.
Old Dec 15, 2010 | 02:01 PM
acf6's Avatar
acf6
When its cold, i also have a slight knock in the engine for the first ~minute, so subscribing
Mini2
Sep 11, 2010 09:34 PM
460k&n
2004 - 2008 F150
Apr 18, 2010 09:17 PM
capwater
1997 - 2003 F150
May 15, 2008 07:54 PM
crichards21
1997 - 2003 F150
Feb 2, 2008 06:00 PM
lifted_01_SD
22
Jun 25, 2006 07:11 AM
