Glowing exhaust manifolds
Old 12-20-2010, 07:02 PM
steveyg's Avatar
steveyg
steveyg is offline
No codes, a couple came up when we first started like the iat but we replaced those and still have the glowing manifolds
Old 12-20-2010, 07:04 PM
Henry10s's Avatar
Henry10s
Henry10s is offline
Your fuel pressure looks good. Any exhaust leaks/blockage? Timing issues?
Old 12-20-2010, 07:08 PM
steveyg's Avatar
steveyg
steveyg is offline
Timing looks good base is 10 advances to 28...
Checked for leaks and found nothing.
Think maybe an issue with the stator in the distributor?
Old 12-20-2010, 07:10 PM
Henry10s's Avatar
Henry10s
Henry10s is offline
Your van is possessed. The only thing remaining is stop tomorrow morning at church and pray
Old 12-20-2010, 07:16 PM
steveyg's Avatar
steveyg
steveyg is offline
Haha, Yeah, hoping for a christmas miracle
Old 12-30-2010, 05:41 PM
turbogus's Avatar
turbogus
turbogus is offline
I feel for ya bro, after seeing your posts a few goofy things came to mind;
Previous owner replaced the manifold from one he found at the Trinity test site.
It'll take just a jiffy to cook hot dogs in your engine compartment.
An on board alternative to LED underbody accent lights.
I remember just prior to failure on an old CJ 5 Jeep I had one of the headers was glowing, I could only see this at night but it wasn't bright orange either, shortly thereafter a silver dollar sized hole appeared and I went to a new set of Hookers. I suppose it's time to take 'er in to the Ford garage and hopefully they'll have a current TSB and knowledge to find what truly is the culprit. Best of luck to you, sincerly.
Old 04-08-2013, 12:15 AM
Maoramos's Avatar
Maoramos
Maoramos is offline
ford e350 v8 460 1993 Rv jambore
I have the same problem, I want to know how I fix it.
Old 04-08-2013, 06:26 AM
maples01's Avatar
maples01
maples01 is offline
I had that once, it was a cracked head, no leaks either, but it would glow, good luck.
Old 04-08-2013, 11:38 AM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
i once had a 300-6 with the glowing exhaust, it was severely retarded ignition timing. it came with a severe loss of power, but i managed to drive it home over 50 miles after its timing jumped.
Old 04-13-2013, 01:41 PM
Maoramos's Avatar
Maoramos
Maoramos is offline
Originally Posted by steveyg
1992 e-350 7.5 460
Long story short, my father and I are traveling cross country in our rv. We're stuck in va bc we had a faulty fuel injector that needed to be replaced. Fixed that and cleaned the rest, but when we went for a test drive we noticed the exhaust manifold glowing bright orange.
So we've replaced the:
Plugs and wires
Cap and rotor
Map
O2 sensor
Removed the cat and put a 3" exhaust
IAT sensor
Changed fuel filter
Fuel pressure regulator
Replaced vacuum lines and checked for leaks (18 in-hg with a .5 variation at idle)
Checked base timing (set at 10)
Tps read smooth resistance
Coolant temp sensor reads ok
Egr opens at low gear/rpm not wot
Replaced ignition module
We get a pinging/hesitation under heavy load
So we're towing a 24 foot car hauler and will be under load the whole way across and have no idea where to turn next. This sucks..
Thanks for any input, really, we're desperate
I solve this problem?
I have the same case
Old 04-13-2013, 01:46 PM
Maoramos's Avatar
Maoramos
Maoramos is offline
my ford is the same, I have advanced about 30 degrees and the temperature in the manifold, but I think that progress excesio. and
bad tuning the engine?
FL2
6.7L Power Stroke Diesel
63
08-08-2022 05:58 AM
fordpride
15
05-23-2016 01:00 PM
Firefighter6601
13
02-07-2016 04:17 PM
BuickBrian
11-02-2015 04:41 AM
BroncoBuddy
1978 - 1996 Big Bronco
15
11-04-2003 10:36 PM
Quick Reply: Glowing exhaust manifolds
