window install help needed
Old Nov 30, 2010 | 07:25 PM
jaye's Avatar
jaye
I got my glas for the side windows today and put them on using the tape;extremely loose wouldn't stay on. What do you recommend using to hold the glass in the window lifts.
Thanks in advance.
Old Nov 30, 2010 | 07:53 PM
52 Merc's Avatar
52 Merc
It sounds like you need either thicker tape, thicker glass, or to adjust the channel tighter. I'd start with thicker tape. I'd also run the whole mess down to the local glass shop so they can see what you need and hopefully they'll have the magic stuff to make it work.
Old Nov 30, 2010 | 09:05 PM
BBKtech2's Avatar
BBKtech2
A glass shop is great advice! They would definitely have what you needed. I'd just have them install the tracks. The tape needs to hold the window tight in the track. It takes some good raps with a deadblow to seat the track onto the glass edge when the tape is of proper thickness.
mgargiullo
Mar 29, 2014 04:07 AM
petercrabbe
Jan 11, 2014 08:14 PM
SDTruckMan
2004 - 2008 F150
32
Jun 15, 2007 05:26 AM
Widall
1983 - 2012 Ranger & B-Series
May 26, 2006 12:57 PM
Charger73400
Dec 30, 2005 10:31 PM
