S. California Chapter Join Chapter, Leader:
Engine Lag
Old Oct 25, 2010 | 12:13 PM
rtorres's Avatar
rtorres
Engine Lag
I replaced the ICP, IPR, High Pressure Oil Pump and cleaned my EGR and I have a little lag at take off but goes away once it kicks into second gear. No codes are showing but someone suggested replacing my Back Pressure Sensor? any suggestions?
Old Oct 25, 2010 | 03:19 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
What are you using to read the codes?
Old Oct 25, 2010 | 04:36 PM
rtorres's Avatar
rtorres
Mechanic has a snap on code reader. I dont know the model, but its the size of a laptop
Old Oct 25, 2010 | 05:08 PM
SteveBricks
FTE Emeritus
Oh, ok...I misunderstood. I thought you were doing the code reading.
My truck has always been laggy...it's a 6.0 trait. Is your truck running differently than it used to?
Old Oct 25, 2010 | 05:19 PM
rtorres's Avatar
rtorres
I talked with a Powerstroke mechanic he suggested I cahnge my exhaust back pressure sensor. I wanted to know if anyone has done this and did it make a difference?
I have a 2004 F350 PSD. Everyone on here has been great and all feed back is greatly appreciated.
I really didn't notice any lag prior to replacing ICP IPR and High Pressure Oil Pump
Old Dec 8, 2010 | 09:59 AM
SteveBricks
FTE Emeritus
I'm wondering how this worked out.
Old Dec 8, 2010 | 10:20 AM
rtorres's Avatar
rtorres
Steve, I to have lagged. I have'nt repalced the Back Pressure Sensor yet. I talked to the powerstroke mechanic and he said since no code was showing up, that he would like to look at the truck first. Here's something interesting though: I woke up one morning to dead batteries. My glove compartment did'nt close all the way thus causing my light to stay on and drained my batteries. I replaced both of them and my truck ran great with no lag. That lasted about a week and the lag returned. I am determined to get this fixed and will keep you updated. If you have any suggestions give me a call.
Old Dec 9, 2010 | 03:00 PM
orng1's Avatar
orng1
To many sensors. Go away SMOG. It's a diesel!
