What have you done to your truck today?
#9976
#9978
There's a thread on here somewhere, where a guy figured out a set of motor mounts and stuff that make them fit, but it doesn't sound all too hard. Just like any engine swap, a bit of work would be required.
#9979
#9980
I'm about to head outside and get the new TC seated, but I need some help with the flexplate....how do I know I'm putting it on the right way? I know that it's balanced with a weight in one corner and that it works with the harmonic balancer to balance the engine, but how do I tell it's on right? It doesn't appear that the bolts have any special pattern to them and there's no indentation, slot, etc. to make sure it goes on the right way. I've got a 302 with a C6.
#9982
#9983
I was asking Matt a question, I'm going outside now, lol.
And Gary, I sent you the PM first then asked here - not out of disregard for your response, but because I was trying to figure something out quick. You replied right after I posted here. lol
I'll let ya'll know what I can get done. I'm off! lol
#9984
![Wink](images/smilies/wink.gif)
#9985
lol. As you've probably figured out, I highly value your knowledge, Gary. And the fact that you've helped me to get a very nice part that I otherwise couldn't have afforded - that means a lot to me. Thank you. ![Smilie](images/smilies/happy0161.gif)
As far as the truck, I got the TC seated after squeezing my wide self almost completely under the truck...I'm friends with Matt on facebook and I told him about it and he acted like I needed to put 3qt of fluid in before I put it on....needless to say, I was glad when he said he was kidding. LOL it was heavy enough with like 1/8 qt in it, I can only imagine having it full and trying to manhandle it into place whilst laying on my side. Only reason I even put fluid in it was because I had watched a youtube video where a guy said he had put ATF on the shaft of the TC so it wouldn't go into the seal dry, so I dumped a little in the TC since I had the bottle in my hand anyway.
I also got the flexplate bolted in, but not torqued yet since I ran out of light. It is as you said, Gary, it only lines up one way. The bolt holes are spaced in such a way that there's only one way it can line up. After several tries and having to put the access plate back on several times after it fell off as I played with the flexplate....it's bolted in.
Tomorrow I torque it all down and get the trans bolted back up to the block, and then get the cooler lines, shifter linkage and speedo cable back in place. Hopefully I can get the dipstick tube back on and get it filled back up too.
I do have a question though - do I need to use threadlocker on the TC bolts?
#9986
#9987
#9988
#9989
