lightning engine capability?
Old Oct 19, 2010 | 11:49 PM
montrese04's Avatar
montrese04
i know the specs already but was wondering if this engine setup was decent for some towing? lets say 8,000lbs every blue moon but being a good DD with decent MPG (lets say16mpg with mixed driving NON-loaded) on my 1990 f150 extended cab frame
  • f250 leafs and springs
  • lightning engine setup and the upgraded lightning e4od tranny (whatever that might be)
should i keep the 4:10 gearing lightning uses or go with something else
Old Oct 20, 2010 | 12:25 AM
93MARKIII's Avatar
93MARKIII
i think you should sell me anything lightning you have and stick with what ya got
Old Oct 20, 2010 | 12:27 AM
93MARKIII's Avatar
93MARKIII
the tranny is the same as all the rest i think...post 93 that is...
Old Oct 20, 2010 | 02:02 AM
86F150302's Avatar
86F150302
Good luck with 16 mpg...
Sure the 351 will tow fine. 8000 pounds? Depends on more than just the engine. Gears.. Well that depends on tire size.
Tranny is pretty much the same as any other E4OD.
http://www.nloc.net/vbforum/gen-1-li...sion-guys.html
Old Oct 20, 2010 | 04:17 AM
TexasGuy001's Avatar
TexasGuy001
The Lightning drivetrain and gears are good for towing, but you won't clear 15 mpg I don't think. What size tires do you have?
Old Oct 20, 2010 | 06:07 AM
skyfox10's Avatar
skyfox10
You might be able to get around 15mpg or so if the engine is setup right and you drive it easy. I've had two trucks with 351's and both got 12.5 average. I advanced the timing on my truck this summer and now average 15.1mpg. This is a 4x4 truck with an E4OD 3.08 gears and 32" tires.
Gearing not only depends on tire size, but also how you plan on using the truck. I wouldn't want 4.10 gears in my DD truck, even with the 32" tires. You'll be turning some serious RPM's if you spend much time over 70 mph. I average 75mph on the highway, so 4.10's are not an option for me. I'm looking at 3.73's because they will be perfect for me if I ever go up to a 33" tire.
If you don't drive on the highway a lot, and you want your truck to leave everyone behind at a stoplight, keep the 4.10's. Please keep us posted on your build. I've often considered buying a wrecked lightning and dropping the drivetrain in my truck.
Old Oct 20, 2010 | 01:07 PM
montrese04's Avatar
montrese04
still haven't decided exactly which way I'm going to go as far as suspension. I'm thinking either
F250 Springs in the back with the lightning springs in the front with some factory wheels and tires or perhaps 22in tires but with street friendly tires
or
F250 springs all around with a 2-3in lift with 22in rims with some midly high tires (women love lifted trucks for some reason LOL)
and my MPG is more valued then towing capabilities so 3.73 is the way to go from what i'm understanding (correct me if i'm wrong) seeing as i'm not racing the truck nor am i going to even go in the mud with it. just need it to haul a 8000lb trailer every blue moon. and be a reliable daily driver
Old Oct 20, 2010 | 03:32 PM
redlightning93's Avatar
redlightning93
Why not just buy a Lightning
Old Oct 20, 2010 | 04:19 PM
lew52's Avatar
lew52
I wouldn't do anything with the gearing untill you kow what diameter tire your going to use .....Lew
Old Oct 20, 2010 | 04:33 PM
rla2005's Avatar
rla2005
I averaged around 14 MPG with my last two '93 Lightnings, unloaded running 70 MPH on the interstate. Around town mileage was around 8....
I towed a my flatbed trailer loaded with a 642B Bobcat every once and awhile. I tow the same trailer with my current '92 F350, the mileage is the pretty much the same at 10 MPG.
The F350 is a 4x4, 5.8L engine, E4OD and 3.55 gears.
Old Oct 20, 2010 | 07:31 PM
Diesel_Brad's Avatar
Diesel_Brad
or
So let me get this straight. You want a supercab lifted f150 w 4:10s to get 16mpg? NO WAY IN HELL. you will be lucky to get 13
my lightning that is lowered(less wind resistance) gets a all time high of 16 on a 400 mile all hyw trip
3:73s would maybe get you 14mpg
95centurion
Apr 8, 2016 03:39 PM
wittenmeier
Feb 23, 2014 09:35 AM
Mud&Snow
1997 - 2003 F150
Feb 29, 2012 01:30 PM
joewaldner
Dec 30, 2008 12:02 AM
andrew31690
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Oct 6, 2006 02:22 AM
