1990 F350 4x4 7.3 Diesel Parts
Category: Drivetrain
Price: $1200
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): S2000
Item Condition: PA
Engine: Part suitable for diesel truck
What front axle
If it is a solid axle 60 which it should be what would you want for just the axle and steering? You would probably get more money out of it parting to be honest with ya unless you luck up and find someone that is looking for that setup
this has a coil sprung 8 bolt dana 44, it was an aftermarket conversion from a 4x2 to a 4x4, was formerly an ambulance! I wish it was the D60, although i have a few `78-9 D60s.
Dang
I didnt even pay attention to the coil spring. Will the 78-9 fit a 90 250 still. I am wanting to do the solid axle swap and then lift my truck for a whole lot less. LOL Let me know how much for one if it will fit.
I was wondering if you had any steering parts? i have been looking for the steering knuckle and possibly shaft that it is attached to inside the steering column. ( i mainly just need the knuckle but might have to have them both) Also, do you have the bracket that mounts to the firewall that holds the column in place and are the tabs on it still attached? how much would you want for those parts?
Thank you very much,
Zach
If you would like pictures of what i am talkin about just let me know.
Zach
