MAJOR ANNOUNCEMENT Predator For 6.0L
Old 01-13-2004, 11:24 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
<b><font color=red>NEW!</font></b><h3>Diablo Predator For 2003 - 2004 6.0L Power Stroke Diesel Ford Trucks, SUVs And Vans!</h3><p align=justify><b>The Diablo Predator was engineered to raise hell!</b><p align=justify><font face="helvetica, arial, helvetica" size=2>The Predator is the world's <b>first</b> flash tuner product for the 6.0L Power Stroke! The Predator is a tunable performance module, which utilizes flash technology to reprogram the original ECU chip for optimum performance and drivability.<p>The 6.0L Predator features state of the art tuning with lower exhaust gas temperatures than external power add-on boxes.<p><b><u>Features</u></b><li>Easy to use. Novice users can select preset performance settings.</li><li>3 Performance settings!<ol><li>45 HP tow file for heavy towing</li><li>65 HP all-around use, light towing, fuel economy performance tune</li><li>100 HP, no towing unless you have an EGT gauge install</li></ol><li>speed limiter adjustments</li><li>State of the art OBD-II diagnostics live sensor reading (not just a simplistic code reader)</li><li>up to 30 minutes data logging at 90 samples per second that can be viewed on the Predator screen or uploaded to your desktop pc</li><li>Fast programming time</li><li>300% larger viewable screen than other tuners (compared to other company products for the 7.3L Powerstroke)</li><li>Backlit screen allows you to use the tool in full sunlight or total darkness</li><li>Full text OBD-II Diagnostics + diesel specific diagnostics</li><li>Real-time sensor input data monitoring (fuel, MAP, coolant temp, RPM, live diagnostic codes, etc.). Over 100 parameters can be monitored in real time.</li><li>Read and clears DTCs (Diagnostic Trouble Codes) with full text DTC explanation.</li><li>Can reprogram performance tune or restore stock tune <b>even if dealer reflashes the ECU</b></li><li>Port which will allow future download of updates</li><li><b>Lifetime Warranty!</b></li><p><b><font color=red>FREE OVERNIGHT SHIPPING!</font></b>
We expect to begin shipping on Wednesday, January 13th.
Hurry! Intial Quantities Are Limited and only a few dealers in the world will have it!
Go Here to order --- > > http://www.motorhaven.com/customer/p...cat=217&page=1
Old 01-14-2004, 11:39 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
Originally posted by webmaster
[B]I was told that the programmer requires Ford's latest flash. If you don't have it, take it in for it.
When you say latest... which latest...
I have the december flash....
Old 01-14-2004, 01:00 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
A quote from Diablo: "works with the lastest flash only." That's all I have from them.
Old 01-14-2004, 01:13 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Okay, just got an update:
All revisions from Oct 2003 and newer, including the Harley Davidson F-250.
Old 01-14-2004, 03:04 PM
jdadamsjr's Avatar
jdadamsjr
And from what I gather the latest flash was 12-12-03 or there abouts, which I DO have.
Flash Matrix
THANKS !
Old 01-14-2004, 06:46 PM
shendren's Avatar
shendren
shendren is offline
i'm new but are "stickys" the same as an advertisement?
i'm a TDR member (cummins) and it's not the same.
Old 01-14-2004, 07:52 PM
ClubDrof's Avatar
ClubDrof
ClubDrof is offline
Question
Questions, questions, questions
So are you saying this is perfectly safe on a 2004 6.0L PSD with the latest flash or at least I can reinstall the factory flash if something does go wrong?
I've owned my truck for a month and have approximately 1800 miles on the engine -- should I wait a little longer before adjusting the horsepower?
I'm new to this diesel game but I'm itching for a new toy to increase performance. What else do you recommend having in place when using the Predator?
Old 01-14-2004, 08:14 PM
shendren's Avatar
shendren
shendren is offline
so, can i add a sticky to the top and advertise my crap?
Old 01-14-2004, 08:44 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Hire a full time staff, put in thousands of hours over several years building and promoting a site, fork out a ton of money each month maintaining it and you can advertise "your crap" on it.
Old 01-14-2004, 11:05 PM
BagStroke's Avatar
BagStroke
BagStroke is offline
Gauges & Exaust?
With this new Predator do you need gauges and exaust or will it work (stock) safely??
Old 01-15-2004, 11:02 AM
Tekrep's Avatar
Tekrep
Tekrep is offline
Re: Gauges & Exaust?
Exhaust will help keep you EGT a little lower, but you'll never know unless you install the gauges. I'd recommend gauges as the first step in everyone's mod process. However, technically speaking, gauges have no effect on performance or your mods- they just let you know what effect the mods are having on the system. I'm installing gauges now, will monitor and record performance and parameters as stock, then will have a baseline as I do modifications. When done, I’ll have performance and parameter changes for each mod. If something goes wrong, I’ll know where to look to get back to where I need to be. Can you tell I do flight testing?
Old 01-15-2004, 11:29 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
The tow program will not require a larger exhaust. However, gauges are always a good idea, even with stock trucks.
Old 01-15-2004, 11:44 AM
jdadamsjr's Avatar
jdadamsjr
DARN YOU KEN !!!!!
You got the Predator to me too soon !!!
SHUCKS !!!!!!!!!!!!!!!!
my predator just came in and I don't have gauges yet...
Anyone giving odds if it stays in the box or not ?!?!
(I'll take that bet, too !!!)
bye - gotta go play !
on edit - Ken can you pm me on autometer gauges, I think thats the consensus on what will match my interior...
EGT at elast,
boost as a possbility,
and mounting if I don't want to remove my grab handle...
Thanks again for superior service !
Old 01-15-2004, 01:50 PM
GoEIB1's Avatar
GoEIB1
GoEIB1 is offline
Does the engine warranty stay intact with this?
Old 01-15-2004, 05:10 PM
ALASKAF250's Avatar
ALASKAF250
ALASKAF250 is offline
GoEIB1,
That a good question. Also, it says I can get my stock tune back. Is that the flash I started with. I would love to get the MPG back I can deal with the hard start up.
Quick Reply: MAJOR ANNOUNCEMENT Predator For 6.0L
