1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
1987 Ranger XLT Cruise
Old 03-23-2017, 05:22 PM
Tsandnc's Avatar
Tsandnc
Tsandnc is offline
Had a problem going down road, brakes applied all by them selves, their was no give in break pedal, had to pull over, turned off, let sit for a half hour or so while trying to figure out what was going on, didn't find anything except hot hubs, started back up everything is good again, suspect the cruise control. I was messing with it earlier in the drive, about 20 min before it happen, pressed a few buttons, it does not work, anyone know how to test. I know don't press any more buttons, LOL!
Repost, previously posted under wrong forum.
Old 03-24-2017, 01:47 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
Have you jacked it up & checked for a brake that's adjusted too tight? Might be dragging & overheating the fluid.
When my cruise control was'nt working I pulled the trouble codes & BINGO I got a code 29 "vehicle speed sensor voltage is too low." 30 bucks for a new sensor & problem solved. Take a couple minutes to pull the codes.
Old 03-24-2017, 02:14 PM
Tsandnc's Avatar
Tsandnc
Tsandnc is offline
Did not get any codes.
Old 03-24-2017, 03:51 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
And in the FWIW category 1988 was the 1st year that Rangers had a CEL (check engine light) on the dash. Your 87 does'nt have one. So on an 87 the only way to know if theres a trouble code is to hook up a scanner & check.
Old 03-25-2017, 10:31 AM
Tsandnc's Avatar
Tsandnc
Tsandnc is offline
Had codes checked. none. But I did find. Remove the Master cylinder and checked Booster push rod, way to long, 1.35, adjusted in to 1.0, any longer and I would have to draw in master cylinder to mate surfaces. 1.0 seams to be the perfect length to wear the Master cylinder mates up with Booster with no effort, pedal and brakes are fine now, problem fixed. Thanks for advice!
Old 03-26-2017, 01:57 AM
87 XLT's Avatar
87 XLT
87 XLT is offline
Thanks for the update and congrats on finding the problem.
Alex from GA
02-25-2019 09:48 AM
theinrich
10-17-2015 03:06 PM
scoug001
10-15-2008 02:30 PM
madclone
Bronco II
10-03-2007 12:34 AM
afront
10-26-2005 04:41 PM
Quick Reply: 1987 Ranger XLT Cruise
