89 F350 Fun Ton Plow Truck Turbo 460 FiTech
Old 02-23-2017, 07:33 PM
Sick6's Avatar
Sick6
Sick6 is offline
Hi guys, I'm in the process of turning this truck into a do-all beast. Going to try to retain low end torque and fuel economy and use the turbo more as a supercharger to accent the top end.
Budget turbo builds are a lot of fun for me, this will be my 7th turbo build, 2nd turbo build using a FiTech. Here are a couple links from previous builds:
https://www.ford-trucks.com/forums/1...leeper-16.html
https://www.youtube.com/channel/UCh2...b7J6neUhQgEFVA
Here's the truck...
Here's where i'm at now...
http://www.youtube.com/watch?v=aa6Ba...ature=youtu.be
Old 02-23-2017, 07:39 PM
Sick6's Avatar
Sick6
Sick6 is offline
460 rebuilt well over 10 years ago, has around 6k miles
D9 block D3 heads D2 4 barrel intake
Economy cam, peak hp about 3500 all done about 4000
Truck mani's 2.5's y into 3" straight pipe
Stock c6
Transfer case???
Dana 60 4.10 gears
Rear end??? 4.10 gears
I will post up some pics of the t case and rear end, see if you guys can tell me what these are.
Old 02-23-2017, 08:34 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Transfer case is probably an np208 and rear is a ford/sterling 10.25.
That's what stock would be.
Old 02-23-2017, 08:45 PM
Sick6's Avatar
Sick6
Sick6 is offline
Thank you sir. It should be all stock except it was originally a 351w efi c6 truck.
Good to hear from you again.
Old 02-23-2017, 09:20 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
That year used the same transfer case and rear axle no matter what engine it had.
There should be a little round tag on the back of it. Newer transfer cases were 1356, and a little different. I think you could get the 1356 with a pto, is the biggest difference. I don't remember.
If you keep that rear, and the cover is rusted out, look up the 08 aluminum finned diff cover. It's typically only $50 on eBay.
I'm ready to see this project take shape!
Old 02-24-2017, 12:09 AM
BS51993's Avatar
BS51993
BS51993 is offline
How did you keep the bumper straight? I see many of these with plows and the bumper is either crooked or bent to fit.
Old 02-24-2017, 12:29 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Personally, I think it's taking pride in your work...
Yeah, it may take a little longer to get it right, but it won't look stupid.
And possibly, the other you've seen, got ran into something and bent it.
Old 02-24-2017, 10:37 AM
sdiesel's Avatar
sdiesel
sdiesel is offline
t case - likely a 1356 in this year. very good design but for potential of pick up tube coming loose, even so i ran one for months on just a cap full of oil by accident
1356 with pto plate: tonners with duals, or sno package, kinda scarce now.
1345 till '87
1356 till early '90's then onward
208: mostly gm and lighter rigs
the bw 4407
then 271 the monster but pump wears thru case
i follow your work closely am always impressed . this fitech is a surprise after your deep commitment to mechanical over electronic builds in the past. the little ford is my favorite! its my go to reference for my rig.
Old 02-24-2017, 01:33 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Early to mid/late 80s had np208
Early 90s had 1356....
Late 80s is where the transition was, and I'm not sure when it changed. I know my 87 has an np208 and my 92 has a 1356... I'll have to look on my 90, because I can't remember.
Old 02-24-2017, 03:06 PM
mrollings53's Avatar
mrollings53
mrollings53 is offline
8C3Z-4033-A Aluminum Finned Differential Cover 8C3Z-4033-A Aluminum Finned Differential Cover
It's a shame I already bought the Dorman part. I would have bought this one instead if I had known.
Old 02-24-2017, 04:44 PM
Sick6's Avatar
Sick6
Sick6 is offline
Thanks a ton guys! Here are some pics...
Looks like 1356???
Old 02-24-2017, 04:56 PM
Sick6's Avatar
Sick6
Sick6 is offline
sdiesel, efi makes me nervous as hell lol! But after working with the FiTech v6 tbird and most people around here wanting efi now, I figured I would crawl out from under my rock.
Also, it's our third vehicle so just in case the wifey needs to use it...
Old 02-24-2017, 11:55 PM
sdiesel's Avatar
sdiesel
sdiesel is offline
yes to 1356. excellent unit c6 in front of it?
i have easily passed the million mile mark with that combo in a number of trucks, great stuff when gas was under 2/gallon
does it have pto plate?
since i have your ear let ask you something please.
On the 6 project, You mentioned you would be really content with the windsor turbo'ed in a daily driven pick up.
i have a fresh built 6 in a tonner dually4x witth a 5 speed.
using your build design theory can my 6 , how do i ask this,, , can it provide satisfactory, daily, working power, using the remote turbo, the lunatti and so on.
i like how you held timing and manipulated boost- very sensical. for that engine.
the working power part, i cant really put to words rightly.
but i mean a broad, reliable, torque curve and start-every-day reliability.
this should be a p.m. sorry fellas, but his answer is useful to more than just me.
Old 02-25-2017, 06:53 AM
bigcrunch's Avatar
bigcrunch
bigcrunch is offline
Who is Truck Mani ?
Old 02-25-2017, 09:07 AM
sdiesel's Avatar
sdiesel
sdiesel is offline
truck mani
is the grandson of the truck granny!!
Quick Reply: 89 F350 Fun Ton Plow Truck Turbo 460 FiTech
