Torque Pro In Celsius
Dowloaded Torque Pro on my tablet tonight. Been trying to set up the guages. I loaded the ford specific PID's but the coolant and eot are in celsius. Tranny is in F and other reading are also in standard units. These two seem to be stuck in metric for some reason. Ideas? I've been searching for the solution.
There are two possibilities. One is that there are two options for PID's, one *F and other *C or there's multiples of a PID like "method 1", "method 2", "method 3". Choose them all and run the app. Delete the ones that display in *C and keep the *F.
Second is have you run the app with the vehicle yet? They will automatically adjust to use *F once the app is used.
I had both of those circs occur. There was a post on the Torque forums regarding the exact same situation and that's what they said to do. I loaded the PID's like you and saw the same thing. Followed those directions and it worked. Had to go back and delete a few PID's that only displayed *C and kept the *F.
Hope that helps.
Hope that helps.
Correct. I was beating my brain doing the same as I was setting mine up too. Once I located the post on the Torque forums, I gave it a whirl and it worked. I don't recall which temps that had multiple "methods." I just went with all two or three and they would do their thing once the app was working with the vehicle. Then I just removed the *C ones.
Hope that helps.
Hope that helps.
akblackfoot: another one that might not have been fixed is the transmission temp. If it tracks exactly with coolant, you'll need to edit the PID and change the OBD Header to read TCM
Assume you are logging data? I just attach the droid to my laptop via USB cable and use Explorer to go move the data files to the PC, then load them into Excel for playing with on that side... Depending on how many PIDs, the frequency of capture and how long you capture for, the files can get pretty big...
Thanks! The Coolant PID actually says TCM on it. Is that transmission fluid or coolant it will read?
Easiest way to do this is plugged in with the truck running -- all the valid PIDs will show up as green when you set up a new gauge...
Yes, l am trying to log it. I go into the menu and start tracking, but when I attempt to share it via email the file will not attach. I can select the file I want and choose to use email. However, I will get an empty email with no file. I will have to try to hard connection to put into Excel. I use email easily for FORScan files and use Excel to convert from CSV files to be able to read them.
Thanks for reps and I rep'd ya back for your answers
