Radiator support wont line up-dumb problem
Took rad support out and motor for rebuild work. Put rad support back and with it resting on the frame, it doesn't line up (3/4" too high) with the 2 bolts in the fenders on either side. It should fit below the lip and even the 4 vertical (both l and r) don't line up with the bracket. I'm totally miffed, it just doesn't fit. I did not one thing with any of it. Just removed it, painted it, put it back. Wthek am I doing wrong?
Maybe the cab support brackets are rotted through too, and the front of the cab tipped down without the fenders holding it up?
Jeff's Bronco Graveyard sells them.
It's obviously a little too far gone to weld in Framesavers.
http://shop.broncograveyard.com/Truck/products/1130/
1985 Bronco
08-20-2017 09:32 PM
pholmes350
06-21-2016 02:41 PM
bluestang65
20
06-25-2014 10:43 AM
