Best auxillary light to supplement high beams? 2012 f250
I have an auxbeam 20 inch light bar in my bumper where the front license plate holder would be. I have it wired to a switch with a relay in the cab. It is crazy bright and I love it. The only problem is that it is not exactly legal to run it on the road in my state, PA. It does a really good job however and makes your vision much better.
This is what I run on my truck. It is a rough country bracket with a knockoff LED lightbar. Mine is wired to a relay that is switched on and off by the highbeams. It works great.
Yes. That is what I am looking for! Would love to see a pic at night and see how it is wired to the high beams.
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
I also used a headlight harness extension. On that harness, I found the highbeam wire and spliced in the switched lead to the relay harness. That way I did not cut the factory harness at all. I believe I bought that off of eBay, sorry I do not have a link.
Here is the light I used.
Strobes N More EFlood 8640 Warning Light
Here is the bracket.
https://www.amazon.com/Rough-Country...ht+bar+bracket
I hope this helps. I don't have any pictures at the moment, maybe later I can get some for you. I would not hold your breath though, my day is kind of full.
Yes, it is very bright. It actually washes out the headlights and illuminates pretty much everything. I can see a bit of yellowish light from the stock headlights, since I never changed out the bulbs. That is one of the next things on my list to do.
I will caution you that these lights throw a lot of light out, but not at a far distance. It is great for the back roads I drive every night since there are lots of curves and such. On the highway, you would probably be better with some sort of a HID spot light, or something similar.
I did think of putting it on a separate switch, but I did not want to have to reach over to turn it on and off every time a car approached me. If I want light up front, I just turn on the headlights.
I went the cheaper route. I use Hella FF75 auxilliary driving lights that are triggered by the Hi-Beam circuit. I tied the coil of a relay to one of the High Beam wires, and the power for the Halogens comes off of a separate fused circuit coming from the battery.
https://www.amazon.com/HELLA-0082848...8ZV3VEDFHTJ528
These are low-tech, narrow-beam H7, 55 watt halogens, and I use them to extend the range of my Hi-Beams. They can light up the road 200 meters (over 650 feet). I have them aimed to where the light of the stock Hi-Beams falls off.
(NOTE: some day I still want to get a 30" Rigid LED light bar for my grill.)
Attachment 162473
Attachment 162473
I agree with getting an auxbeam light bar. I have a 20" and it is very bright, as stated earlier it basically washes out the headlights. For less than $60 i got the light bar and the harness which is hard to beat. Another option though if you want to spend more money is the rough country kit that mounts in your grill. Here is a pic of my light bar, it has 20% tint on it and is still bright.
