How to fold down the back seat of a crew cab
So tonight I spent some time with the video scope dissecting the latch behind the larger (60%) portion of the back seat, the smaller section (40%) folds down with a strap on the side of the seat. The jack and such is behind the smaller section.
This is the latch plate at the back of the cab.
The latch:
The other side. This side has a small metal "nub" sticking through an opening, right side of latch in the picture. This nub is what actuates the latch
To operate it you will need a long screwdriver. As you can see in the picture below (this is a top down shot of the latch, left side of picture faces rear of truck), when the seat is latched the nub is accessible from the opening on the left (between the latch plate and latch). Feel around behind the top of the seat, it's pretty easy to find (behind the headrest). Get your screwdriver into the left opening. You want the screwdriver to be on the seat side of the nub, then push the nub towards the rear of the truck, it should release fairly easily. Hopefully this makes sense. Once you know what you are doing it can be done in about 5 seconds.
Seat folded down.
The latch:
Seat folded down.
Works great, bought it for a spit plug on a 5.4 so I could see what I was doing. Countless uses thereafter.
Whistler WIC-3509P Wireless Inspection Camera Kit https://www.amazon.com/dp/B0087WRRPE..._p668xb09YFB3G
I'd be careful about surrounding the amp too much...those fins indicate a fair amount of heat being dissipated. Likewise, surrounding the subwoofer could either insulate and dull the bass, or make it rattle.
The sub in the previous generation is larger.
It's a shame there is so little storage behind the rear seats now. I used to carry my tow straps and shackles back there; you could easily mount a fire extinguisher and first aid kit back there, too.
It seems there is less *dedicated* storage in the back of the 2017? I'm reserving judgement on the pop-up storage compartment under the rear seats. It looks flimsy and certainly does not fold totally flat into the floor, but I'll have to try one first.
There is so little space behind the rear seats they figured it would not be necessary for the user to go behind the seat with the amp / sub. However, there is a reason for the user to get behind the seat where the jack is stored. The reason the latch exists on the sub / amp side is so that dealer service can access this equipment in the event of a malfunction.
