New member, another build.
Old 05-25-2014, 09:31 PM
bct222's Avatar
bct222
bct222 is offline
New to the forum although I have visited looking for info in the past. Lots of great builds and photos here so I thought I might as well share a few . As soon as I figure out the photo thing ( I did create an album) I'll share what I've taken and give some details. I am about 2/3 thru the build so I have plenty.
Old 05-25-2014, 10:44 PM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Phantom of the Phorum
Welcome to FTE!
I wish I was 2/3 of the way with mine. I have my chassis finished and I'm starting on body work. I HATE body work.
Old 05-26-2014, 12:45 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Welcome to FTE!
Since you already have an album of photos, it's easy to put pics in your posts. Here's one way.
While you're making a post on FTE, select the pic you want to post from your album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Old 05-26-2014, 12:59 AM
AXracer's Avatar
AXracer
AXracer is offline
to put a pic in an album or gallery, it must first be on the web, not just on your hard drive. Easiest way is to first put them on a free photo storage site such as Photobucket. Watch the photo file size limit if posting to a gallery here.
Old 05-26-2014, 05:23 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Good to see another rescue of a dead project truck. Thanks for sharing - looking forward to watching your final push:
(I captured the image URL by right clicking, picking the obvious option, and pasting it into the dialog box after selecting the yellow postcard looking icon from the menu bar in the 'Reply to Thread' page. Nothing too it.)
DW
Old 05-26-2014, 08:42 AM
bct222's Avatar
bct222
bct222 is offline
Thanks for all the help.
With all the sheet metal on it shows a little potential.
Old 05-26-2014, 12:21 PM
Drewski 2's Avatar
Drewski 2
Drewski 2 is offline
Except for the rear window looks to be chopped close to what mine is.
Old 05-26-2014, 01:35 PM
bct222's Avatar
bct222
bct222 is offline
Drew,
What is really funny is I modified my grill to use 56 buckets and trim rings. I liked the way it turned out but the cost of chroming it has me thinking twice.
I also did a 55 grill pictured in my avatar.
Old 05-26-2014, 02:01 PM
bct222's Avatar
bct222
bct222 is offline
Tear down time
Old 05-26-2014, 02:08 PM
jrockdiddy's Avatar
jrockdiddy
jrockdiddy is offline
Looks like a No Limit Eng. 4 link. I like it
Old 05-26-2014, 03:45 PM
bct222's Avatar
bct222
bct222 is offline
I believe you are correct from what I was able to find when I did my research . I'm not sure about the front IFS . I think it may be a Fat Man.
Old 05-26-2014, 03:58 PM
EffieTrucker
It's looking really nice.
Old 05-26-2014, 06:16 PM
bct222's Avatar
bct222
bct222 is offline
I removed the cab and took the chassis to the body shop to make sure it was square and level.
1/4 out on the right rear
Back at the shop. Time to strip the chassis.
Removed the T5 tranny. With the cab chopped so much and the seat so low a third pedal just didn't work.
Motor out. Seller claimed the engine was built top to bottom. Time to do a little investigation.
Old 05-28-2014, 09:19 AM
bct222's Avatar
bct222
bct222 is offline
Motor was stroked to 347 c.i. Ford racing crank, girdle, h-beam rods, Kieth Black pistons, Trick Flow heads, Crane cam, ARP fastners, Canton 7 qt oil pan, balanced and blue printed.
New valve covers and seals, painted and ready to go back in.
Old 05-28-2014, 09:42 AM
wallster's Avatar
wallster
wallster is offline
Looks great! I'm jealous of your rear end... SUSPENSION! (that sounded weird!)
Wally
Quick Reply: New member, another build.
