How do I remove the HPOP on my 7.3?
I have the hoses off. The fuel bowl off. The bolts (3, I think) out. The HPOP is still in tight and I'm afraid of damaging it.
What do I do to get this thing out so I can fix it? |
Did you remove the reservoir and the bolt that hold the gear to the HPOP?
If you want some instructions on how to take it out, click this link (Terminator Engineering), go to the Tech link at the top, and there's picture instructions that will show you step by step how to get the HPOP out.
Got it out. Cleaned, installed new longer plug and torqued properly. Put it back in and I got tired. Plus I need to find my big torque wrench to sinch down the gear bolt. I read in another thread that you have to fill the HPOP with fresh oil. How or where do I do that?
There's a plug on the top right-hand side of the reservoir lid. Unbolt that to fill with oil. Only need to put in at most a quart, most likely 3/4 a quart. If you add more than that, it will just keep draining into the oil pan.
gear bolt
im try tring to put my hpop back after fixing it ... i took off my resivor do i need to fill it back up? how many in /lb do i torque down the gear bolt
Yes, put back in about a half quart and the torque for the HPOP gear bolt is 95 ft/lb.
Does it have to be timed
It doesn't have to be timed
Originally Posted by woodnthings
(Post 11954220)
:-X06 |
Manly Men don't need no stinkin instructions!!:D:D:D
Smokie |
Originally Posted by Smokiesman
(Post 11955823)
Smokie |
Originally Posted by fordpride
(Post 11956116)
The first thing I do is through the instructions in the trash
Smokie |
Not me, I read them till I see them in my sleep. Maybe thats why I don't sleep. I should quite doing stuff. Nah.
