How do I remove the HPOP on my 7.3?
Old 08-13-2010, 10:15 PM
PJ-Hunter's Avatar
PJ-Hunter
PJ-Hunter is offline
I have the hoses off. The fuel bowl off. The bolts (3, I think) out. The HPOP is still in tight and I'm afraid of damaging it.
What do I do to get this thing out so I can fix it?
Old 08-13-2010, 10:20 PM
Riffraff Diesel's Avatar
Riffraff Diesel
Riffraff Diesel is online now
PREMIUM SPONSOR
Did you remove the reservoir and the bolt that hold the gear to the HPOP?
Old 08-13-2010, 11:58 PM
Pocket's Avatar
Pocket
Pocket is offline
If you want some instructions on how to take it out, click this link (Terminator Engineering), go to the Tech link at the top, and there's picture instructions that will show you step by step how to get the HPOP out.
Old 08-14-2010, 12:33 AM
PJ-Hunter's Avatar
PJ-Hunter
Got it out. Cleaned, installed new longer plug and torqued properly. Put it back in and I got tired. Plus I need to find my big torque wrench to sinch down the gear bolt. I read in another thread that you have to fill the HPOP with fresh oil. How or where do I do that?
Old 08-14-2010, 06:24 AM
Pocket's Avatar
Pocket
Pocket is offline
There's a plug on the top right-hand side of the reservoir lid. Unbolt that to fill with oil. Only need to put in at most a quart, most likely 3/4 a quart. If you add more than that, it will just keep draining into the oil pan.
Old 05-30-2011, 07:16 PM
stanhruza's Avatar
stanhruza
stanhruza is offline
gear bolt
im try tring to put my hpop back after fixing it ... i took off my resivor do i need to fill it back up? how many in /lb do i torque down the gear bolt
Old 05-30-2011, 07:44 PM
Riffraff Diesel
PREMIUM SPONSOR
Yes, put back in about a half quart and the torque for the HPOP gear bolt is 95 ft/lb.
Old 06-14-2012, 09:47 PM
greenbeast7.3's Avatar
greenbeast7.3
greenbeast7.3 is offline
Does it have to be timed
Old 06-14-2012, 10:07 PM
fordpride's Avatar
fordpride
fordpride is offline
It doesn't have to be timed
woodnthings's Avatar
woodnthings
woodnthings is offline
Old 06-15-2012, 06:41 AM
microdevil45's Avatar
microdevil45
microdevil45 is offline
Originally Posted by woodnthings
I love when they have pictures... reading instructions just sucks!!!
Old 06-15-2012, 09:26 AM
Smokiesman's Avatar
Smokiesman
Smokiesman is offline
Manly Men don't need no stinkin instructions!!
Smokie
Old 06-15-2012, 10:27 AM
fordpride's Avatar
fordpride
Smokie
The first thing I do is through the instructions in the trash
Old 06-15-2012, 10:59 AM
Smokiesman's Avatar
Smokiesman
I do that to till I get stuck ! then I got to rummage through the trash!!
Smokie
Old 06-15-2012, 11:30 AM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1 is offline
stinson 108-1
Not me, I read them till I see them in my sleep. Maybe thats why I don't sleep. I should quite doing stuff. Nah.
Diesel 724
16
07-08-2020 01:22 PM
tbax46
07-23-2016 11:13 PM
barko4
02-16-2015 09:47 PM
Dieselgrowl
17
08-09-2013 09:00 AM
papadelogan
04-07-2009 05:11 PM
Quick Reply: How do I remove the HPOP on my 7.3?
