Hissing sound when A/C is on
Hello everyone I have a problem with my 2000 Expedition 4x4 XLT. When I have the A/C on theres this hissing sound comming from the rear, I think on the drivers side. Any ideas?
Also my truck have rear air. Thanks ~Gage~ |
Originally Posted by Gage2502
(Post 8945347)
Maybe the rear blend door is stuck. Just a thought.
Thanks for the info, weird thing is that it only makes that hissing noise when in A/C mode.
I didnt know there was a blend door in the rear. ~Gage~ |
From what I've read the rear blend door uses an electric motor instead of vacuum as in the front.
You're hearing refrigerant flow through the orifice at the rear evaporator core. It echoes through the overhead ductwork, and is rythmic with the cycling of the compressor. You'll hear the same "hissing" noise from every '97-'03 Expy/Navi with rear A/C. It's more pronounced when the vehicle is a bit low on refrigerant.
JL |
There are two blend doors in the rear, both are electirc. They are on the p/s not the driver side. Typically what breaks is the gear on the blend door actuator, not the door itself. When they break you get a clicking / thumping noise, not a hiss. In the front the axle on the door tends to break.
I have the same problem in my '03..but I think mine is due to a leak somewhere. I've shot it with refridgerant and still have the hissing sound that is only coming from the rear. The shot only lasts a day at most..any ideas? It's getting steamy here in Virginia Beach and having a Black Expo with black leather seats isn't any fun with no a/c
So I still having problems with my A/C when its on its not cold at all front and rear. Does this sound like it needs to be recharged? So I bring it to the dealer?
Thanks ~Gage~ |
i have the same exact problem with my 2000 expy 4.6
i will recharge my a/c system this weekend. i will keep you updated. |
I was going to try this stuff, what do you think? IDQ - Auto A/C Products & Sealing Solutions
(Post 9079151)
Originally Posted by kerim1
(Post 9076757)
(Post 8945347)
Thanks for the info CHELLIE, my A/C hasn't worked in a few years it just blows warm air front and rear so I hoping that all it needs is a recharge.
~Gage~ |
