Hissing sound when A/C is on - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 05-30-2010, 05:13 PM
Gage2502's Avatar
Gage2502 Gage2502 is offline
Gage2502 is gaining momentum as a positive member of FTE.Gage2502 is gaining momentum as a positive member of FTE.
Hello everyone I have a problem with my 2000 Expedition 4x4 XLT. When I have the A/C on theres this hissing sound comming from the rear, I think on the drivers side. Any ideas?
Also my truck have rear air.
Thanks ~Gage~
Old 05-30-2010, 08:14 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Thanks ~Gage~
Usually a hissing sound would be a vacuum leak, but I know of no vacuum lines going to the rear unless there is a line in the console.
Old 05-31-2010, 05:25 AM
bnewkirk bnewkirk is offline
bnewkirk is starting off with a positive reputation.
Maybe the rear blend door is stuck. Just a thought.
Old 05-31-2010, 05:15 PM
Gage2502's Avatar
Thanks for the info, weird thing is that it only makes that hissing noise when in A/C mode.
I didnt know there was a blend door in the rear.
~Gage~
Old 05-31-2010, 06:23 PM
Moto Mel's Avatar
From what I've read the rear blend door uses an electric motor instead of vacuum as in the front.
Old 06-01-2010, 09:02 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
You're hearing refrigerant flow through the orifice at the rear evaporator core. It echoes through the overhead ductwork, and is rythmic with the cycling of the compressor. You'll hear the same "hissing" noise from every '97-'03 Expy/Navi with rear A/C. It's more pronounced when the vehicle is a bit low on refrigerant.
JL
Old 06-01-2010, 09:08 AM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.
There are two blend doors in the rear, both are electirc. They are on the p/s not the driver side. Typically what breaks is the gear on the blend door actuator, not the door itself. When they break you get a clicking / thumping noise, not a hiss. In the front the axle on the door tends to break.
Old 06-06-2010, 09:58 AM
ladytex70's Avatar
ladytex70 ladytex70 is offline
ladytex70 is starting off with a positive reputation.
I have the same problem in my '03..but I think mine is due to a leak somewhere. I've shot it with refridgerant and still have the hissing sound that is only coming from the rear. The shot only lasts a day at most..any ideas? It's getting steamy here in Virginia Beach and having a Black Expo with black leather seats isn't any fun with no a/c
Old 07-05-2010, 04:30 PM
Gage2502's Avatar
So I still having problems with my A/C when its on its not cold at all front and rear. Does this sound like it needs to be recharged? So I bring it to the dealer?
Thanks ~Gage~
Old 07-05-2010, 10:12 PM
kerim1 kerim1 is offline
kerim1 is starting off with a positive reputation.
i have the same exact problem with my 2000 expy 4.6
i will recharge my a/c system this weekend. i will keep you updated.
Old 07-06-2010, 04:35 PM
Gage2502's Avatar
I was going to try this stuff, what do you think? IDQ - Auto A/C Products & Sealing Solutions
Old 07-06-2010, 04:43 PM
CHELLIE's Avatar
CHELLIE CHELLIE is offline
CHELLIE is gaining momentum as a positive member of FTE.
It may work if the leak is coming from a loose hose crimp or o ring, but most A/C leaks come from the compressor shaft front seal, and the comp needs to be replaced, if you dont have the tools to change just the comp seal, and changing the comp seal is a hard job, its better to just r&r the entire comp and clutch assy. look for oil around the front of the a/c comp clutch area, anywhere you find oil at on a/c parts, you will have a a/c leak, dish soap and water in a spray bottle will help to find a/c leaks, fords love to leak freon at the evaporator area, inside the cab.
Old 07-06-2010, 04:47 PM
CHELLIE's Avatar
the a/c service ports have a shrader valve in them, and love to leak, when removing the caps, if the valve area is wet with oil, replace the shrader valves, hope that helps, Chellie
Old 07-06-2010, 04:56 PM
CHELLIE's Avatar
Thanks ~Gage~
Hi JL is right, if you are not loosing freon, and your ac is cold, your hearing the liquid freon being sprayed into the evaporator tube inside the evaporator, thats what causes the evaporator to get cold, liquid changing into a gas, three devices cause the freon to get cold, #1. orfice #2. expansion valve #3 capillary tube, all 3 cause a liquid freon to change to a gas inside a evaporator to cause it to get cold. hope that helps, Chellie
Old 07-06-2010, 07:08 PM
Gage2502's Avatar
Thanks for the info CHELLIE, my A/C hasn't worked in a few years it just blows warm air front and rear so I hoping that all it needs is a recharge.
~Gage~
strange A/C noise fordman19762003 1999 to 2016 Super Duty 8 05-25-2014 07:10 PM
hissing noise from rear drivers side when A/C is running kalpesh Expedition & Navigator 4 11-12-2012 04:51 PM
A/C hissing airborne89 2004 - 2008 F150 17 05-26-2009 10:40 PM
A/C noise Supercrewzin01 2004 - 2008 F150 7 12-09-2008 05:02 PM
A/C panel hisses after shutdown rount5 1994.5 - 1997 7.3L Power Stroke Diesel 2 03-29-2007 01:38 PM
Tags
2002, ac, air, coil, door, engine, evaporator, expedition, f250, ford, hissing, lincoln, mode, navigator, rear, sound, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
