rebuilding my $150 78 bronco (they paid me to take it)
hello to all. It started with a rusty 78 bronco with a fresh rebuilt 351m. the guy found me an wanted me to take it home, but i had to many projects going on. my wife decided she wanted it so she bought the bronco . it sat in the yard for a year an we ended up going are separate ways. I had been paid to haul away 87 f-150 4x4 xtra cab. i got it running and ended up trading the ex for the bronco. I didnt tell her i already had a 4"lift a non rusty front clip and doors and set of 35's . I ended up blowing up the 9" couldn't afford to rebuild it, so i swapped in d-60 i had in the back yard . I put on rear disc brake kit from TSM inc and had to have a new driveline made. Well the more i worked on the bronco the more rust i found plus i had a flint stone floor boards,also the front frame horns had cracked and someone attempted to weld the cracks and made it worse . i found a good tub and frame so for the last few months i have been swapping things over . Yesterday i dropped the new tub on to the frame . i still have a ton of work to do . I have been taking lots of pics.
You can see them at 1978 Ford Bronco pictures, photos, videos, and sounds | SuperMotors.net take a look an tell what you all think ! i am working on a real tight budget (lack of money) lol . i will keep adding pics. to supermotors as i get things put back together. I know its nothing super fancy, but its mine . i want to go wheeling ,tired of putting cars together, it got boring plus i am i into truck now . its time for me to stop typing now got to go work on the bronco now . so good bye for now:) |
I prefer my wrecks to be a little more put together. See the DonKo in my Garage.
awesome job!!! just amazing, im doing a frame off with my 78 but in a one car garage...... was wandering if you have any front radius arm brackets with the shock mounts. i cant find them anywhere, mine are bent to crap and cant get the shocks on. did you strip and paint the frame yourself??
bahanovi@mtu.edu |
thank you and yes i stripped the frame and painted it i am working very tight budget so i get to do everything myself. i really don't mine doing everything, i call it a leaning experience.its pretty much stock except for the lift and d-60 rear axle . i do work in a wrecking yard ,so i will look around . it took while for me to get the dual shock set up. of course there will be more pics as i get things done .i just put some up of the bucket seats i got from a Mazda Navajo. passenger side seat was a direct bolt in ,the driver side seat needed some modification. i will let u know if i have those things mtufreerider:-X22
thanks!! Mine is going a lot slower than yours but im doing a lot of body work to mine and then gona try and stuff a 7.3L diesel into it. good luck and keep up with the pics.
Hello again,i had to pull the drivers seat again to move it over a 1/2" because my center console didn't fit. I have also added a 3g alternator to the motor plus cleaned it up an did some painting to the motor. Next i will be putting on a roll on bed liner in the tub. i did put more pics up at 1978 Ford Bronco pictures, photos, videos, and sounds | SuperMotors.net . an yes i have a set of shock mounts . i will keep posting as things progress
pics of bronco, now that i figured it out
here some pics of the bronco ,now that i figured out how to post them . i am better at wrenching than i am at computers.https://www.ford-trucks.com/forums/p...ictureid=35239This is what i started with.https://www.ford-trucks.com/forums/p...ictureid=36572 this the new non cracked frame.https://www.ford-trucks.com/forums/p...ictureid=36574this is 4"lift and d60 in rear with disc brakes
https://www.ford-trucks.com/forums/p...ictureid=35235motor an trans in.https://www.ford-trucks.com/forums/p...ictureid=36558drive lines,gas tank, bumper and hitch installed.https://www.ford-trucks.com/forums/p...ictureid=36559getting ready to set body on frame.https://www.ford-trucks.com/forums/p...ictureid=36560going down on frame smoothly.
https://www.ford-trucks.com/forums/p...ictureid=36561successhttps://www.ford-trucks.com/forums/p...ictureid=36564 doors are on .https://www.ford-trucks.com/forums/p...ictureid=36563mocking in Mazda Navajo bucket seats.https://www.ford-trucks.com/forums/p...ictureid=36566 don,t laugh at welds ,but modified front Navajo seat frame.https://www.ford-trucks.com/forums/p...ictureid=36567rear frame needed to elongate both holes.
https://www.ford-trucks.com/forums/p...ictureid=36569painted motor and put 3g alternator in.https://www.ford-trucks.com/forums/p...ictureid=36568new/used intake for motor.https://www.ford-trucks.com/forums/p...ictureid=36565an this whats left of old bronco . well that's all i have done for now . i will keep the pics coming
Looks great! Keep up the good work.
Do you have a 9 inch rear end you can send me? I need one for my Bronco. I am sure you have one some where on those racks. What kind of paint on the frame and engine parts? I plan to start rebuilding a D44 for an SAS project and I want to paint the axle housings. |
well the paint was ace hardware premium gloss black $2.00 a can the engine paint was placsi kote ford blue engine paint from local parts house i'm on a real tight budget so nothing special about the paint an yes the yard has a ford nine inch several around .need to call an talk to ryan he can give you a price plus shipping 541-382-1987 bend auto wreckers
Are you going to move the roll bar to the new one? I have only seen one other Bronco with one in a junkyard in WV.
i got that roll bar from a parts bronco years ago an yes im going to save it. don't know if its going in the new bronco yet . i kinda want to put a full cage in back for running without the top. my budget or lack of budget lol will determine what goes back there
Awesome!! can't wait to rip mine apart.
