Hazard flasher location
I cannot find the flasher unit for the 4 ways in my 1991 F250. Unless if it share the relay unit with the turn signal flasher. I found the turn signal unit. Per the Chiltons manual it is either on the back side of the fuse block or under the instrument panel. It is definitely not on the fuse block. I cannot find what looks like the typical flasher unit, round can. Help anyone.
Thx Pat |
Standard method... turn on flashers.. and hear the click...
It should be right where the brake pedal is.. on its own mounting. |
I have two 1989 f250's, and the 4 way flasher is mounted on a bracket up high over passenger side kickpanel. Up on the right side of the glovebox. It's hard to see.
found my 4 way flasher!!!
I found my 4 way flasher for my 91 F250 behind the glove box stuck on the right side. It was kinda hide behind the air vent tube. What ever possess ford to play hide-and-go-seek with the 4 way flasher is beyond me....
