Hazard flasher location - Ford Truck Enthusiasts Forums
Old 04-04-2010, 07:53 PM
pleckrone pleckrone is offline
pleckrone is starting off with a positive reputation.
I cannot find the flasher unit for the 4 ways in my 1991 F250. Unless if it share the relay unit with the turn signal flasher. I found the turn signal unit. Per the Chiltons manual it is either on the back side of the fuse block or under the instrument panel. It is definitely not on the fuse block. I cannot find what looks like the typical flasher unit, round can. Help anyone.
Thx Pat
Old 04-04-2010, 08:29 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Standard method... turn on flashers.. and hear the click...
It should be right where the brake pedal is.. on its own mounting.
Old 04-05-2010, 10:10 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I have two 1989 f250's, and the 4 way flasher is mounted on a bracket up high over passenger side kickpanel. Up on the right side of the glovebox. It's hard to see.
Old 07-22-2014, 09:45 AM
Big AJ Big AJ is offline
Big AJ is starting off with a positive reputation.
found my 4 way flasher!!!
I found my 4 way flasher for my 91 F250 behind the glove box stuck on the right side. It was kinda hide behind the air vent tube. What ever possess ford to play hide-and-go-seek with the 4 way flasher is beyond me....
2013 E150 Flasher Location Dennis N 1968-2013 Full Size Vans 0 02-23-2017 10:40 AM
Expedition 2003 Flasher Problem Kingstyle01 Electrical Systems/Wiring 4 02-19-2014 02:35 PM
Turn Signal Flasher Location pacrewchief Escape & Escape Hybrid 1 12-06-2009 02:15 PM
turn signal flasher 2000 F-150 XL ohheflies 1997 - 2003 F150 1 02-16-2004 08:41 AM
Turn Signal Flasher fbclock Explorer, Sport Trac, Mountaineer & Aviator 2 02-25-2002 12:42 PM
Tags
2002, 2006, 53, 94, 96, bronco, f150, f250, f350, flasher, ford, hazard, hazzard, location, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
