How much does it weigh?
Rough estimate...
How much does my truck weigh? F350, Crew Cab, Auto, 2wd |
Probably around 6500 lbs
well, he's got a crew.
i got a single cab 4x4 5speed and mine weighs in at 6550. |
I was going to guess around 7200, but that might be a little high.
Red |
i'ma guess for him it will be close to 6700 with out 4x4 stuff.
I know a t-case can weigh a good 150 lbs and the front axle is heavy too. |
My supercab 4x4 with me in it and both fuel tank full, ridiculously homemade gooseneck ball in the bed welded to a few hundred pounds slab of iron, but otherwise empty weighed at a State of California approved scale when I registered it from out of state now has the official weight of 6480 lbs.
The unofficial dump scale after a weigh back, truck empty but for me and my wife and 1 tank full said we were 6900 lbs. |
yea. I got a gooseneck hitch like that also. Mines all 3/8's plate steel.
My 96 crew 4x4 with one tank full and me in it 7200lbs. Guessing a 2wd pretty close to 6800. While on the topic of weight, how much does a long block powerstroke weigh?
Originally Posted by Brown Falcon
(Post 8371184)
Rough estimate...
Ok, thanks guys
Mine was on the scales last month and it read 6200.
Originally Posted by 95_Dually
(Post 8374012)
I was surprised that mine was that light too. I always thought it would tip the scales at 7,000 lbs +.
I have the aluminum wheels, and both tanks were almost empty. I also had everything cleaned out of the truck. It was just the truck with zero add-on's in the truck. |
mine is 6800 + or - 50 every time I go over the scales to get feed (certified scales)
p.s. '97 f250 4x4 short bed super cab xlt trim
