How much does it weigh? - Ford Truck Enthusiasts Forums
Old 01-15-2010, 07:52 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
Rough estimate...
How much does my truck weigh?
F350, Crew Cab, Auto, 2wd
Old 01-15-2010, 08:23 AM
triskadek's Avatar
triskadek triskadek is offline
triskadek is starting off with a positive reputation.
Probably around 6500 lbs
Old 01-15-2010, 08:31 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
well, he's got a crew.
i got a single cab 4x4 5speed and mine weighs in at 6550.
Old 01-15-2010, 08:35 AM
Red97350 Red97350 is offline
Red97350 is gaining momentum as a positive member of FTE.
I was going to guess around 7200, but that might be a little high.
Red
Old 01-15-2010, 08:46 AM
Talyn's Avatar
i'ma guess for him it will be close to 6700 with out 4x4 stuff.
I know a t-case can weigh a good 150 lbs and the front axle is heavy too.
Old 01-15-2010, 08:51 AM
triskadek's Avatar
My supercab 4x4 with me in it and both fuel tank full, ridiculously homemade gooseneck ball in the bed welded to a few hundred pounds slab of iron, but otherwise empty weighed at a State of California approved scale when I registered it from out of state now has the official weight of 6480 lbs.
The unofficial dump scale after a weigh back, truck empty but for me and my wife and 1 tank full said we were 6900 lbs.
Old 01-15-2010, 08:56 AM
Talyn's Avatar
yea. I got a gooseneck hitch like that also. Mines all 3/8's plate steel.
Old 01-15-2010, 09:44 AM
fuelman fuelman is offline
fuelman is gaining momentum as a positive member of FTE.
My 96 crew 4x4 with one tank full and me in it 7200lbs. Guessing a 2wd pretty close to 6800. While on the topic of weight, how much does a long block powerstroke weigh?
Old 01-15-2010, 11:01 AM
phillips91 phillips91 is offline
phillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud of
Quote:
Originally Posted by Brown Falcon View Post
Rough estimate...
According to the page I am looking at, a 1995 crew cab f350, 2wd xl, auto, gasser has a dry weight of 5185 lbs. Add another 350 lbs for the diesel and that gets it up to 5535. 40 gallons of fuel is another 400 lbs, so up to 5935. Add your fluids and you are at about 6000. Then add on any other goodies you have (cab steps, tool boxes, etc). I would guess somewhere in the mid 6's.
Old 01-15-2010, 01:04 PM
Ok, thanks guys
Old 01-15-2010, 08:36 PM
95_Dually's Avatar
95_Dually 95_Dually is offline
95_Dually has a great reputation on FTE.95_Dually has a great reputation on FTE.95_Dually has a great reputation on FTE.95_Dually has a great reputation on FTE.
Mine was on the scales last month and it read 6200.
Old 01-15-2010, 08:55 PM
joe_13894 joe_13894 is offline
joe_13894 is gaining momentum as a positive member of FTE.joe_13894 is gaining momentum as a positive member of FTE.
Quote:
Mine is 6700. I can't see how they could be that different. I have an automatic so that could be a hundred there. And my hitch is honkin huge and weighs in at 150 lbs. (I have a 42" extension for towing behind my slide in camper). I wonder what else is different?
Old 01-15-2010, 09:02 PM
95_Dually's Avatar
I was surprised that mine was that light too. I always thought it would tip the scales at 7,000 lbs +.
I have the aluminum wheels, and both tanks were almost empty. I also had everything cleaned out of the truck. It was just the truck with zero add-on's in the truck.
Old 01-15-2010, 10:11 PM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
mine is 6800 + or - 50 every time I go over the scales to get feed (certified scales)
Old 01-15-2010, 10:12 PM
helifixer's Avatar
p.s. '97 f250 4x4 short bed super cab xlt trim
How Much Does Your Truck Weigh ?? Paratrooper84 6.7L Power Stroke Diesel 30 02-11-2017 10:39 AM
460 weight GeneGregory Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 01-17-2017 11:40 AM
69 F-250 CS weigh ? coloradotrk 1967 - 1972 F-100 & Larger F-Series Trucks 20 10-07-2014 06:50 PM
Highboy weight hickory1991 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-17-2011 04:14 PM
Tags
08, 09, 1994, 1997, 2006, 73, diesel, escape, f150, f250, ford, today, truck, weigh, wheigh
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
