Electronic throttle body replacement
Hello all! I've been searching through the forums and found some of you have had the same problem as me.
While driving home my yellow wrench light came on and I had no power at the pedal, even though the engine was idleing smoothly. This happened with no warning and went away when I turned the truck off and restarted it. About 4 miles later it did it again. I immediately went to a nearby dealership only to find out my electronic throttle body needs replaced. Needless to say at this time of year 500+ dollars is not readily available, although I need my vehicle for work. I do not know a thing about ETB's but did a little research online and found many aftermarket ones at a much better price than Ford's(surprise). My question I guess is what are my alternatives to factory replacement? Can I remove and clean this component or replace it with something of better quality? I'm not into high perfomance with my truck but if I could get a little better throttle response or gas mileage I'm all ears. My truck is a 2004 Supercrew 4x4 XLT w/ 5.4 Triton. Around 74,000 miles and well taken care of. Miles are nearly all highway. I look forward to hearing from you guys. |
Thank you shotgunz those were helpful. I think I will try to clean it before replaceing it. What can it hurt?
Originally Posted by Jason441
(Post 8315423)
(Post 8315423)
What can it hurt?
etb
ihad mine replaced under some kinda ford/california emissions control warranty. i had the ESP warranty with 100 deductable. after the shop had had my truck for about a week they called and told me the good news, and reefunded my deductable. this is about the only break i've got with the truck. 05 5.4
Originally Posted by Reagan K
(Post 8321918)
I would think the ETB is covered by the Cali Emissions Warranty, but I can't find anything specific. Dealer says it isn't. I'm going to write emails to the California Air Board and FoMoCo, but any insights on this matter would be greatly appreciated. Thanks. .Yukes |
2 Attachment(s)
This is what my throttle body looked like,..before & after,..used contact cleaner and toothbrush, was pretty black & dirty.
