Electronic throttle body replacement - Ford Truck Enthusiasts Forums
Old 01-03-2010, 02:48 PM
Jason441 Jason441 is offline
Jason441 is starting off with a positive reputation.
Hello all! I've been searching through the forums and found some of you have had the same problem as me.
While driving home my yellow wrench light came on and I had no power at the pedal, even though the engine was idleing smoothly. This happened with no warning and went away when I turned the truck off and restarted it. About 4 miles later it did it again. I immediately went to a nearby dealership only to find out my electronic throttle body needs replaced. Needless to say at this time of year 500+ dollars is not readily available, although I need my vehicle for work. I do not know a thing about ETB's but did a little research online and found many aftermarket ones at a much better price than Ford's(surprise). My question I guess is what are my alternatives to factory replacement? Can I remove and clean this component or replace it with something of better quality? I'm not into high perfomance with my truck but if I could get a little better throttle response or gas mileage I'm all ears.
My truck is a 2004 Supercrew 4x4 XLT w/ 5.4 Triton. Around 74,000 miles and well taken care of. Miles are nearly all highway.
I look forward to hearing from you guys.
Old 01-03-2010, 03:53 PM
Thank you shotgunz those were helpful. I think I will try to clean it before replaceing it. What can it hurt?
Old 01-03-2010, 04:03 PM
shotgunz's Avatar
shotgunz shotgunz is offline
shotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to all
Quote:
You're welcome.
What can it hurt?
Exactly! If it works, you'll save a bunch of money.
Old 01-04-2010, 10:08 PM
Reagan K Reagan K is offline
Reagan K is starting off with a positive reputation.
etb
ihad mine replaced under some kinda ford/california emissions control warranty. i had the ESP warranty with 100 deductable. after the shop had had my truck for about a week they called and told me the good news, and reefunded my deductable. this is about the only break i've got with the truck. 05 5.4
Old 02-15-2011, 06:47 PM
yukes555 yukes555 is offline
yukes555 is starting off with a positive reputation.
Quote:
I've got a 2005 FX4. My ETB just failed with just under 60k miles, 3500 after purchasing it Certified Pre-Owned. Dealer says it's not covered under the extended powertrain because it's electronic. Sounds pretty fishy to me.
I would think the ETB is covered by the Cali Emissions Warranty, but I can't find anything specific. Dealer says it isn't. I'm going to write emails to the California Air Board and FoMoCo, but any insights on this matter would be greatly appreciated. Thanks.
.Yukes
Old 02-15-2011, 07:20 PM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
This is what my throttle body looked like,..before & after,..used contact cleaner and toothbrush, was pretty black & dirty.
Electronic Throttle Body Heads up glockholiday 2015 + Expedition & Navigator 1 09-08-2016 10:04 AM
04 Ford Explorer 4.0 Bank 1 & 2 Lean jbizub5192 Explorer, Sport Trac, Mountaineer & Aviator 4 01-16-2015 11:17 AM
2005 Expedition Check Electronic Throttle Control, P0720, P2106, O/D Off Blinking, Limited Power WhyFord 1997-2006 Expedition & Navigator 21 06-27-2013 04:29 PM
My experience removing and cleaning the throttle body and intake adapter on a 5.4 2V vze2sgxa 1997-2006 Expedition & Navigator 5 03-02-2011 09:30 AM
My experience removing and cleaning the throttle body and intake adapter on a 5.4 2V vze2sgxa 1997 - 2003 F150 10 12-30-2008 10:57 AM
Tags
04, 1999, 2004, 2006, 42, 54, body, electronic, f150, ford, motor, sensor, throttle, triton, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
