need a 2ton rear end? free to FTE in need
Free to FTE member in need!I have 2 good rear ends 1 is from my 56 f600 with 42k miles I put new wheel cyl. on it but then pulled it out when I found a 2sp I have now pulled the 2sp and replaced it with dana 80 with 3.31 axle ratio. Both have the square housing and six lug bolt pattern .... 1 is a rockwell with 6.80 ratio the 2sp is an eaton 15200 series with 6.33/8.81 ratio Note: they are currently listed on craigslist (but not for free) I would like to see them get a good home .... I'm in morgan hill ca. pm with a phone # and I'll call you
what are the ratios on the 2 spd if you don't mind my asking.
Originally Posted by amish77
(Post 7830547)
the 2sp is an eaton 15200 series with 6.33/8.81 ratio Regards, Rick |
rustyrelic at least deserves some rep points for his offer :-X22
Originally Posted by Krewat
(Post 7833737)
