does MPG increase with biodiesel?
B20 is about the same price as diesel right now at a local station. if I use some B20, say half a tankful, would I expect to see an increase in my feul mileage?
Any advice? |
Try: https://www.ford-trucks.com/forums/forum168/
I'm not running a diesel, but based on the chemistry, my guess is 'no'. |
But you sure will clean out your fuel system.......be ready with new fuel filters....
There is a good correlation between density and heat content. So, if the API gravity spec of B20 is the same as straight diesel, the mileage is most likely going to be the same.
Jim |
I have been running my homebrew, 100% (B50-60 in the winter) for almost a year now. My own rough estimates show around a 8-10% reduction in MPG. Feels like a corresponding percentage in power reduction. Doesn't matter to me though, knowing that it is better for my engine and its fuel system.
I found a BTU comparison: -#2 pump petro diesel=140,000 BTU/gal. 48 cetane -B100 soybean based=130,000 BTU/gal. 55 cetane |
BTW, I've found running B20 resulted in no noticeable loss in power, and a negligible change in MPG.
I believe the lubricity gains with that quantity, however, are well worth it. |
I ran bio in my diesel probably 5-6 times and noticed a mileage decrease of about 10-15% like the other guy above
Bummer. At 11 mpg I don't want to get worse gas mileage.
There are other biofuels under development that may get better mileage than petroleum distillates (diesel, jet, etc).
"Air New Zealand is coming out in strong support of alternative fuel, saying that more than 3,000 pounds of fuel can be saved on a 12-hour flight if that flight is flown on a jatropha-seed-oil biofuel blend instead of straight Jet A." Jatropha Oil Biofuel Update Jim |
Originally Posted by KLWdesigns
(Post 7563571)
mpg's
I have recently purchased a DP Tuner. My fuel mileage did go up a couple MPG's. Plus there's a whole lot more ppower!
(Post 7530242)
Any advice? |
I've not noticed a drop in mpg using b-20 and I 'hand calculate' my mpg after each fill up. I ran b-20 until the local station raised the price, now B-20 is about .15 cents a gal more than #2 diesel and #2 is WAY to expensive as it is...It don't look like that 'Hope and Change' is working out so well. Or is it?
