Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids and Mileage
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Alternative Fuels, Hybrids and Mileage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-22-2009, 03:18 PM
KLWdesigns's Avatar
KLWdesigns KLWdesigns is offline
KLWdesigns is starting off with a positive reputation.
does MPG increase with biodiesel?
B20 is about the same price as diesel right now at a local station. if I use some B20, say half a tankful, would I expect to see an increase in my feul mileage?
Any advice?
__________________
2001 F250 PSD 4 x 4 auto crew cab K&N air filter, 24" wipers, Monster muffler, Baja fenders over 35"s
my other hangout is AZBaja.com[SIGPIC][/SIGPIC]
  #2 (permalink)
Old 05-23-2009, 04:16 AM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
Try: http://www.ford-trucks.com/forums/forum168/
I'm not running a diesel, but based on the chemistry, my guess is 'no'.
  #3 (permalink)
Old 05-23-2009, 12:16 PM
BPofMD's Avatar
BPofMD BPofMD is online now
Old-Timer
BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all
But you sure will clean out your fuel system.......be ready with new fuel filters....
__________________
BPofMD - Bud
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB CrewCab Arizona Beige
2007 Arctic Fox 30' Fifth Wheel - 1997 Lincoln Mark VIII LSC
Join the Maryland Chapter click HERE
  #4 (permalink)
Old 05-26-2009, 10:20 AM
jimandmandy jimandmandy is offline
jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE.
There is a good correlation between density and heat content. So, if the API gravity spec of B20 is the same as straight diesel, the mileage is most likely going to be the same.
Jim
  #5 (permalink)
Old 05-30-2009, 05:09 PM
binuya's Avatar
binuya binuya is online now
binuya is gaining momentum as a positive member of FTE.
I have been running my homebrew, 100% (B50-60 in the winter) for almost a year now. My own rough estimates show around a 8-10% reduction in MPG. Feels like a corresponding percentage in power reduction. Doesn't matter to me though, knowing that it is better for my engine and its fuel system.
I found a BTU comparison:
-#2 pump petro diesel=140,000 BTU/gal. 48 cetane
-B100 soybean based=130,000 BTU/gal. 55 cetane
  #6 (permalink)
Old 05-30-2009, 05:13 PM
binuya's Avatar
BTW, I've found running B20 resulted in no noticeable loss in power, and a negligible change in MPG.
I believe the lubricity gains with that quantity, however, are well worth it.
  #7 (permalink)
Old 05-30-2009, 06:12 PM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
I ran bio in my diesel probably 5-6 times and noticed a mileage decrease of about 10-15% like the other guy above
__________________
08 F350 SRW KR CC LB 4X4 Dark Copper Metallic V-10/Torque Shift, Loaded UP!!
10 Escape XLT
This isn't your father in law's Buick. Step back
and no one gets hurt!
  #8 (permalink)
Old 06-01-2009, 01:18 PM
KLWdesigns's Avatar
Bummer. At 11 mpg I don't want to get worse gas mileage.
__________________
  #9 (permalink)
Old 06-03-2009, 09:21 AM
There are other biofuels under development that may get better mileage than petroleum distillates (diesel, jet, etc).
"Air New Zealand is coming out in strong support of alternative fuel, saying that more than 3,000 pounds of fuel can be saved on a 12-hour flight if that flight is flown on a jatropha-seed-oil biofuel blend instead of straight Jet A."
Jatropha Oil Biofuel Update
Jim
  #10 (permalink)
Old 06-20-2009, 09:52 PM
pancreas pancreas is offline
pancreas is starting off with a positive reputation.
Quote:
Have you flashed you CPU or anything? I was seeing 14.6 mpg bought a bully dog and was shocked my c/h ave is around 21.1 atm at 3 months of daily driving. I run B20 as often as i can.
  #11 (permalink)
Old 06-22-2009, 06:17 PM
KLWdesigns's Avatar
mpg's
I have recently purchased a DP Tuner. My fuel mileage did go up a couple MPG's. Plus there's a whole lot more ppower!
__________________
Tags
73 , bio , biodiesal , biodiesel , biofuel , diesel , f150 , f250 , ford , fordtruckcom , gas , increase , mileage , mpg , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
