1975 ford f250 carb problems
hey guys everytime i have to start my truck i have to put bit of gas down the carb also on my truck i have air filter with oil resevoir in it is that normal for my inline 6 with carter carb?
On my 460 with a Carter AFB, I had the same symptoms until I replaced the accelerator pump. No problems since. Not sure what type you got on the Inline 6 though.
This carburetor is probably a Carter YF. Is the choke closed when you go to start it?
carb problems
not sure what u mean about the choke is there a manual choke on a 1975 ford f250 custom?
i have bought a rebuild kit for the carb will that help? |
When you start a carbureted engine when it's "cold," you must press the gas pedal once. This "loads" the choke. The choke plate is the top-most plate in the throat of the carburetor. After you press the pedal, the choke plate should be closed.
A manual choke would not have been factory. The above procedure is for an automatic choke. A manual choke must be closed...well, manually. Don't worry about the rebuild kit until we actually know if there's a problem or not. Don't waste money on parts you don't even know you need. |
carb problems
ok thanks ill check that out
