1975 ford f250 carb problems - Ford Truck Enthusiasts Forums
Old 05-20-2009, 10:12 PM
arich arich is offline
arich is starting off with a positive reputation.
hey guys everytime i have to start my truck i have to put bit of gas down the carb also on my truck i have air filter with oil resevoir in it is that normal for my inline 6 with carter carb?
Old 05-21-2009, 12:49 PM
tractoman's Avatar
tractoman tractoman is offline
tractoman is starting off with a positive reputation.
On my 460 with a Carter AFB, I had the same symptoms until I replaced the accelerator pump. No problems since. Not sure what type you got on the Inline 6 though.
Old 05-21-2009, 05:24 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
This carburetor is probably a Carter YF. Is the choke closed when you go to start it?
Old 05-21-2009, 07:38 PM
carb problems
not sure what u mean about the choke is there a manual choke on a 1975 ford f250 custom?
i have bought a rebuild kit for the carb will that help?
Old 05-22-2009, 12:02 AM
fmc400's Avatar
MSEE
When you start a carbureted engine when it's "cold," you must press the gas pedal once. This "loads" the choke. The choke plate is the top-most plate in the throat of the carburetor. After you press the pedal, the choke plate should be closed.
A manual choke would not have been factory. The above procedure is for an automatic choke. A manual choke must be closed...well, manually.
Don't worry about the rebuild kit until we actually know if there's a problem or not. Don't waste money on parts you don't even know you need.
Old 05-22-2009, 06:03 PM
carb problems
ok thanks ill check that out
how to tune carb anthonym92 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 06-14-2015 09:40 PM
Carb question? kcode 1973 - 1979 F-100 & Larger F-Series Trucks 6 10-14-2011 02:59 PM
gas shooting up out of carb logan.hawes FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 12 09-19-2011 02:03 PM
Carb kits and rebuilding Bwillden24 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 34 12-30-2010 05:40 AM
carb/intake questions vtjvt 1973 - 1979 F-100 & Larger F-Series Trucks 11 09-06-2009 04:12 PM
Tags
1975, 460, carb, carburetor, cater, choke, common, f250, ford, manual, pralpims, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
