1993 f250 door won't open
Well, i guess i have been lucky, i haven't had to go on here for a year. I always go here before i even start to take truck apart. 1993 f250 7.3l 4wd,
today my driver side door would not open from the inside. it will from the outside, but it is not pulling something from the inside. I know you guys will know the answer. thanks again, don't know what i'd do without this sight. |
I think your year of truck uses a cable attached from the handle to the release latch. Heard that they can break after a while of use.
I think the change over was in 1987, older trucks use a solid rod instead. I'm not sure, but I think you might be able to take the solid rod out of an 1980-1986 truck door and put it in your truck. Otherwise, just go to a wrecker and find a similar year of truck and take the cable out of it. |
The cable may have just streched if it stretched just un hook it from the handle and twist it around a few times and put it back on this will shorten the cable up and alow you to poen the door i had to do that to mine and it has been fine ever since.
My F100's door handle ripped out of the door where it mounts (slides) in the front, so it may be that as well. I fixed it by riviting in a small 1/2'' by 4'' piece of thin metal to help brace the front clip on the handle.
thanks guys
My 93's driver's door did the same thing. the cable had broken-off. My local salvage yard had a supply of new cables in stock, for $20. Ford won't sell you just the cable, they want mega-bucks for a whole new assembly. For the hassle involved, I wouldn't get a junk yard cable. You don't know how long it will last. Please save yourself a lot of grief and buy a new cable. If you need a link to one, I could probably dig it up.
how hard is it to do. i have had the door cover off before and done the motor for the power windows. if you have a link or p/n that would be great.
I think it might be stretched seems like it still has tension, and I did not hear a pop. |
It took me 20 minutes to swap. Hardest part, was getting the end of the new cable in the latch assembly. I'll find a link for you..
http://i218.photobucket.com/albums/c...lick_here3.gif
Fourth item down on the page... 1350825[***************] 1992-1996[/COLOR][***************] Ford F-Series Pickup Truck Inside Door Handle Cable 19.95[/COLOR]
appreciate it, you had me worried it was going to be a couple hour job
Originally Posted by gbeach
(Post 7393672)
(Post 7392169)
today my driver side door would not open from the inside. it will from the outside, but it is not pulling something from the inside. I know you guys will know the answer. thanks again, don't know what i'd do without this sight. LMC Truck Parts - Page 17 |
thanks kleenax
door problem
got a welder? i have had 1992 & 1990 and the pot metal breaks where the inside door handle bolts to the door, i just took the door panel off and welded it back on
id try askin joe f350 if you can borrow his big hammer i hear it was his tool of choice when he built his 600 hp idi lol
