1993 f250 door won't open - Ford Truck Enthusiasts Forums
Old 04-15-2009, 09:56 PM
gbeach gbeach is offline
gbeach is starting off with a positive reputation.
Well, i guess i have been lucky, i haven't had to go on here for a year. I always go here before i even start to take truck apart. 1993 f250 7.3l 4wd,
today my driver side door would not open from the inside. it will from the outside, but it is not pulling something from the inside. I know you guys will know the answer. thanks again, don't know what i'd do without this sight.
Old 04-15-2009, 10:16 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
I think your year of truck uses a cable attached from the handle to the release latch. Heard that they can break after a while of use.
I think the change over was in 1987, older trucks use a solid rod instead. I'm not sure, but I think you might be able to take the solid rod out of an 1980-1986 truck door and put it in your truck. Otherwise, just go to a wrecker and find a similar year of truck and take the cable out of it.
Old 04-15-2009, 11:12 PM
George D.'s Avatar
George D. George D. is offline
George D. is starting off with a positive reputation.
The cable may have just streched if it stretched just un hook it from the handle and twist it around a few times and put it back on this will shorten the cable up and alow you to poen the door i had to do that to mine and it has been fine ever since.
Old 04-15-2009, 11:20 PM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 has a good reputation on FTE.Dean88 has a good reputation on FTE.
My F100's door handle ripped out of the door where it mounts (slides) in the front, so it may be that as well. I fixed it by riviting in a small 1/2'' by 4'' piece of thin metal to help brace the front clip on the handle.
Old 04-16-2009, 08:20 AM
thanks guys
Old 04-16-2009, 10:09 AM
EMD_DRIVER's Avatar
EMD_DRIVER EMD_DRIVER is offline
EMD_DRIVER is starting off with a positive reputation.
My 93's driver's door did the same thing. the cable had broken-off. My local salvage yard had a supply of new cables in stock, for $20. Ford won't sell you just the cable, they want mega-bucks for a whole new assembly. For the hassle involved, I wouldn't get a junk yard cable. You don't know how long it will last. Please save yourself a lot of grief and buy a new cable. If you need a link to one, I could probably dig it up.
Old 04-16-2009, 10:32 AM
how hard is it to do. i have had the door cover off before and done the motor for the power windows. if you have a link or p/n that would be great.
I think it might be stretched seems like it still has tension, and I did not hear a pop.
Old 04-16-2009, 10:34 AM
EMD_DRIVER's Avatar
It took me 20 minutes to swap. Hardest part, was getting the end of the new cable in the latch assembly. I'll find a link for you..
Old 04-16-2009, 10:39 AM
EMD_DRIVER's Avatar
Fourth item down on the page...
1350825[***************] 1992-1996[/COLOR][***************] Ford F-Series Pickup Truck Inside Door Handle Cable 19.95[/COLOR]
  • Cable Fits Left Hand Or Right Front Door
  • Cable Attaches To The Inside Door Handle And Latch
  • Steel Cable, Plastic Housing
  • Approximately 20 1/2" long (plastic) / 23" long (inc. cable ends)
  • Replaces Dealer # F4TZ-15219A65-A
  • Replaces Worn, Stretched Or Broken Cable That Causes Door To Open Hard
  • This Cable Is No Longer Available At The Dealer
  • Door Handle Cable Fits 1992, 93, 94, 95, 1996 Ford F-150 Pickup Truck
  • Door Handle Cable Fits 1992, 93, 94, 95, 1996 Ford F-250 Pickup Truck
  • Door Handle Cable Fits 1992, 93, 94, 95, 96, 1997 Ford F-350 Pickup Truck
  • Replacement Ford Pickup Truck Door Handle Cable Built To OEM Specifications
Old 04-16-2009, 10:43 AM
appreciate it, you had me worried it was going to be a couple hour job
Old 04-16-2009, 10:45 AM
EMD_DRIVER's Avatar
Quote:
I'd never done one, before this.. That shows you my level of experience...
Old 04-16-2009, 11:18 AM
Kleenax Kleenax is offline
Kleenax is starting off with a positive reputation.
LMC Truck catalog has them for $14.95. They have a GREAT online catalog too, with a good drawing of what all is in there. Link is here:
LMC Truck Parts - Page 17
Old 04-16-2009, 11:25 AM
thanks kleenax
Old 04-16-2009, 11:29 AM
metalman_ickes metalman_ickes is offline
metalman_ickes is starting off with a positive reputation.
door problem
got a welder? i have had 1992 & 1990 and the pot metal breaks where the inside door handle bolts to the door, i just took the door panel off and welded it back on
Old 04-16-2009, 01:18 PM
84 f250 6.9's Avatar
84 f250 6.9 84 f250 6.9 is offline
84 f250 6.9 is starting off with a positive reputation.
id try askin joe f350 if you can borrow his big hammer i hear it was his tool of choice when he built his 600 hp idi lol
99 Crew Cab Rear Door issue X1Lightning 1999 to 2016 Super Duty 3 04-28-2014 12:03 PM
Replace door & remove + install harness 97 F250 Diesel chaines 1987 - 1996 F150 & Larger F-Series Trucks 2 10-19-2013 04:36 AM
2001 F-250 Ext. Cab rear door bholt 1999 to 2016 Super Duty 2 12-02-2012 07:40 PM
Looking for 1993-1997 F250 or F350 94 7.3idi Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 11-09-2012 02:53 AM
F250 front driver door won't open bigtexan99 1999 - 2003 7.3L Power Stroke Diesel 10 09-13-2012 01:01 PM
Tags
19921996, 1993, crewcab, door, doors, drawing, f250, f350, ford, handle, hard, inside, open, rear, replace, supercab
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
