C4 - What's the difference between 6 and 8 Cylinder Versions ?
Greetings from Germany!!!:-X12
Wonder what the differences are between C4s which were originally mounted behind a straight 6 vs. those which came behind a SB V8. Got a used C4 which came out of a British Kit Cobra which was running a British 3,0 Ltr. V6 Ford. This is most certainly not where the tranny originally came from and therefore I wonder if there was a difference and how I could tell 'em apart (without having to disassemble it). I just heard that the ones used behind 6 bangers had just 4 clutch discs(???) and the ones from the 8 Cylinders had 5. Not sure about any details. This C4 by the way is the one where the bellhousing shares the bolts with the pump. I just got me a bell housing that fits both, the tranny and my 289 SBF (with 6 bolts). If there is a difference then will a normal rebuild kit have the parts to make it a V8 version or do I need extra parts ? Any help is much appreciated !!! Thanx !!! |
and the 6 cyl. should come w/a higher stall converter
... Thanx G.C. !!!
Hope there's more C4 Specialists on-line. Really need to know more details. Thanx. |
