Originally Posted by packfan17
(Post 8302979)
Ok, after reading all these posts and checking my code(P0122), I went out and unbolted the assembly. The only problem I have is, how in the world do you pull the plug off of the assembly to clean the contacts? By the way, the truck is a 2002 F-350 4x4 PSD Lariat with 130,000 miles and this is the first time the darn engine light came on.And thanks, this site has been great.
Just buy a new pedal and be done with it :) There is 2 plugs on mine and you just push the release on the clip and pull it off. Just like any other plug or clip. Then spray some contact cleaner on each end and plug them back in. FYI....i had tps issues and lack acceleration and dead pedal...and just did the new pedal and let me tell you, it is NIGHT AND DAY. Truck has alot more throttle response now and no more deal pedal. I have been needing one for a while it seems. Good luck. |
Originally Posted by SilverBullet131313
(Post 8303699)
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"> |
Why is everyone jumping to conclusions. One if its been sitting for 24 days and its cold outside, I would atleast let the truck idle for 10 minutes. My 7.3 did this all the time when it was cold, after about 2 minutes of idling I would have a pedal again.
Sorry to bring this thread back up but I'm now having the problem as described by the op. I have a 2002 though so my question is how do you tell which tps you have? Any pics or part numbers?
Edit: Went to Rockauto and found this picture. This is the one I have. Hollllyyyyyy cowwwwww, it's $577.00 Help help panic panic..... https://cimg2.ibsrv.net/gimg/www.for...0c5bcb31c4.jpg |
