Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 03-11-2009, 01:44 PM
jdecker88's Avatar
jdecker88 jdecker88 is offline
Garage is empty, add now
jdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to behold
Throttle Position sensor location?
Scott(crum71) is having his truck painted and they went to move the truck today and the truck would start but it wouldn't do anything when you push the pedal. Where is the location of the TPS assuming that is the issue?
He hasn't had any issues up til now and he had body work done on the truck IE the bed was removed and fixed and the entire truck was painted. Could the shop have damaged something when they removed the bed?
__________________
Justin (JD)
2000 F-250 CC SB 4x4
Roadside Help NetworkDP-Tuner Guzzle's Truck Site
Pete's Custom Filter Covers Riffraff Diesel Performance
Quote:
Originally Posted by megawatt00 View Post
Kinda tough to embrace the dark side when your an electrician.
  #2 (permalink)
Old 03-11-2009, 01:46 PM
ggirten ggirten is offline
ggirten is starting off with a positive reputation.
I believe it is on the pedal itself. Follow it up.
__________________
Greg
99 F250 SD ext. cab 4x4 7.3l Diesel
V10 Tranny cooler plus heavy duty tranny cooler
Harpoon mod, Tymar mod, Dfuser 18k, DP Tuner high idle, 60 tow, 80 econ, 140 extreme, 2.5 leveling shackles, Cat & muffler delete boost, tranny temp and EGT gauges
  #3 (permalink)
Old 03-11-2009, 01:47 PM
jeff7825's Avatar
jeff7825 jeff7825 is offline
jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.
The TPS is on the throttle pedal. I don't think taking the bed off would affect it in any way.
__________________
Jeffrey
2011 Ford F-150 Lariat Ecoboost
2004 Ford F-350 Lariat 6.0 (New Project)
  #4 (permalink)
Old 03-11-2009, 01:52 PM
jdecker88's Avatar
I wouldn't either only thing back there is the VSS.
Thanks that where he thought it was.
__________________
Justin (JD)
  #5 (permalink)
Old 03-11-2009, 01:57 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Maybe check the fuses?
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-TRANS, DP-TUNER LIVE, MBRP 4" SS, Isspro 3 gauge kit, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
  #6 (permalink)
Old 03-11-2009, 02:03 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
JD this link shows the location and a pic of what the TPS looks like
http://www.dormanproducts.com/docume...s_Sensors2.pdf
__________________
Jim
01 F350 DRW, Autometer Gauges, Custom CAI with Petes Cover, 6" Miter Stacks, 38R Turbo, Casserly SS Injectors, Live tuned by DP-Tuner (F6) , and a bunch of other stuff some show, and some go. PAA #14
www.roadsidehelpnetwork.org
RIP Robin Gone but not forgotten....RIP Mark.. I'll never forget you!!
  #7 (permalink)
Old 03-11-2009, 02:24 PM
crum71's Avatar
crum71 crum71 is offline
1/8 mile Oval Track
crum71 has a great reputation on FTE.crum71 has a great reputation on FTE.crum71 has a great reputation on FTE.crum71 has a great reputation on FTE.
Thanks for posting this for me Justin, Its just my luck, they have had it now for 24 days (ugh) they was putting other vehicles in front of mine,but anyways,they went to back it out of the paint booth today,and it wouldn't do anything. I first thought it was the TPS, but wasnt sure. Does it only have the one on the pedal? A guy out there was telling me that he thought it had another one near the injector pump. Anyone have a clue? I have another one off of that 05' model, I hope it will work,going to run it back out there and see.
__________________
Scott PAA #60 2000 F250 7.3 Lariat Auto 4x4
Quote:
Originally Posted by Markadeck
I love each and everyone of y'all.
01-23-2009, 08:58 AM
  #8 (permalink)
Old 03-11-2009, 02:26 PM
jdecker88's Avatar
Dude don't listen to him if he said injector pump now LOL.
__________________
Justin (JD)
  #9 (permalink)
Old 03-11-2009, 02:39 PM
crum71's Avatar
1/8 mile Oval Track
He just said he thought it had 2 TPS units on it. I thought I had the other pedal here at moms,but I remembered its in the building at the house. I will sneak off in the morning and run it out there. I should make them pay to have it fixed for taking this long to paint it. Its not like I had flames or something like that painted on it also...grrr
__________________
  #10 (permalink)
Old 03-11-2009, 02:42 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
Quote:
Good bodymen are NOT good mechanics, I have learned and visa versa.
It is the rare tech that can do both, and do them well.
I wouldn't worry about them not knowing what is going on.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #11 (permalink)
Old 03-11-2009, 11:20 PM
tdpower's Avatar
tdpower tdpower is offline
2000 Ford F-250
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
Did you check the IVS which is built into the TPS. With the key on press the pedal slowly and should hear a slight click and same when you let back off. I have heard you can clean it out but don't have personal experience with it.
  #12 (permalink)
Old 03-11-2009, 11:47 PM
triskit16's Avatar
triskit16 triskit16 is offline
2000 Ford F-250
triskit16 has a very good reputation on FTE.triskit16 has a very good reputation on FTE.triskit16 has a very good reputation on FTE.
IVS went south in mine, at least I think it was the IVS! I ordered a new pedal assembly because I didnt know what was wrong. It would just go idle in the middle of an intersection. Its very easily bent back into place if it is bent now. Ordered a new pedal when a simple bend wouldve done it!
__________________
-Tristan
2000 F-250 XLT 4x4 Ext Cab SB Auto DP Tuner 60T 80E 120R 4" Turbo Back WW F650 Dash DiPricols MAC Intake Foil Delete CCV Firestone Bags LED...
  #13 (permalink)
Old 03-12-2009, 07:21 AM
VQ2Fast4U's Avatar
VQ2Fast4U VQ2Fast4U is offline
VQ2Fast4U is starting off with a positive reputation.
My truck was acting up with the TPS once, i would be driving and out of no where rpm woould drop to idle with no responce from the throttle. I pulled the TPS and cleaned it with some electrical cleaner and its been fine for about a year now.
__________________
2000 F350 7.3 lots of mods SOLD
2013 F350 6.7 stock... NEW
  #14 (permalink)
Old 03-12-2009, 09:08 AM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.
Here is more info on this issue... I went through all these gyrations several months back, and I've already shared some of this with Scott on the side.
There are two versions of the TPS and pedal assembly, but there is only ONE TPS and it is on the pedal assembly in the cab.
One version has the TPS built integrally into the pedal assembly, and the only way to replace the TPS on that unit is by replacing the entire pedal assembly... something like $75 at either Y2K or FTE Parts Guy, which matches the aftermarket unit pricing from elsewhere and stays with OEM stuff.
With the second style (which mine was SUPPOSED to be since it's a 2002 model, but it actually got a 2001 integral version probably out of convenience for the builders), the TPS is bolted onto the pedal assembly and can be replaced as a simple electronics component... price is somewhere around $35-$40 for the OEM sensor from either of those two guys mentioned above, which, again, is competitive with aftermarket units I've seen.
You CAN clean them out to some degree by spraying electrical contact cleaner inside and letting it dry. This has resolved TPS problems for some people, but not all, and is a cheap first step unless your failure has you dead in the water and you have to get it abck on the road immediately.
As best I can tell from my own efforts and inspections, you CANNOT take the TPS apart without causing significant damage to the unit's housing. You also CANNOT remove the TPS from the integrally built version without some real damamge to either or both portions (sensor and pedal assembly).
R&R is nto bad, but requires some contortion in the floor under the dash on the driver's side. Three bolts, can't remember the size. An air ratchet really helps make the back strain easier (for me, at least).
That said, I still have the 2002 version of the separate TPS that is brand new and has never been installed. Can make a deal for someone in need.
I also still have the original pedal assembly, which I now believe was NOT the problem after all. I think I had some yuck in my tank and when I would accelerate at the just the right (or wrong) conditions - uphill only and at the same rate every time - it would slosh under the pickup foot in the tank and cause an acceleration stumble that mimicked a TPS problem. I need to re-install the original to verify this, and once I do, I just may have a pedal assembly for sale as well.
__________________
Pete (F250_) -- PAA#19
'02 F250 PSD, CC, SB, XLT, 2WD: 231K miles
Basic, low cost, not really performance enhancing mods.
'03 Excursion PSD, 2WD, 165K miles - Stock.
http://guzzle.rbmicro.com/7pt3/Mods.html
  #15 (permalink)
Old 12-31-2009, 06:31 PM
packfan17 packfan17 is offline
packfan17 is starting off with a positive reputation.
Pedal position sensor
Ok, after reading all these posts and checking my code(P0122), I went out and unbolted the assembly. The only problem I have is, how in the world do you pull the plug off of the assembly to clean the contacts? By the way, the truck is a 2002 F-350 4x4 PSD Lariat with 130,000 miles and this is the first time the darn engine light came on.And thanks, this site has been great.
Tags
1996, 2004, 73, audi, f250, ford, location, p0122, position, postion, powerstroke, sensor, sensorf350, throtle, throttle, tps, troubleshoot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
