Ford Truck Enthusiasts Forums
-   Bio-diesel, Propane & Alternative Diesel Engine Fuels (https://www.ford-trucks.com/forums/forum168/)
-   -   condensor gasket (https://www.ford-trucks.com/forums/825105-condensor-gasket.html)
Tom D 02-24-2009 09:51 AM
condensor gasket
I need a piece of sheet gasket material (<6" ID ->6.5" OD) for the top of my evaporator that has a piece of plexiglass on it to view the process. I checked with McMaster-Carr and they have a viton gasket (9473K75) that will work. Do I need to go to that expense ($17.38) for viton or will the neoprene or silicone which is much less expensive work as well. It is subject to methanol/BD at that point. Fabman, what do you use for your "condensor" ? Thanks. Tom
fabmandelux 02-24-2009 06:52 PM
I used a piece of red silicone (1/4") that I had laying around. 4 years and still OK.
Tom D 02-25-2009 08:36 AM
Thanks Don. I have been very busy and haven't done much in the bio dept. Hope you are well. I'll give you a call some morning and catch up on your latest endeavors. Tom
