Default keypad code on 2005 F-150
Just purchased a used 05 FX4 and heard this is the place to come with advice and help on these pickups. I also have a friend whose looking for the default code on his 04 F-250
Can anyone tell me the location of the default keypad entry code on these pickups? Thanks! |
My code for my 06 was on a card inside my owners manual. Im not sure if they print it somewhere on the vehicle itself.
Originally Posted by Flying_Dutchman
(Post 6899294)
I thought it's indicated on the BCM (body control module) which is mounted on the back inside of the cab on the passenger side?
Originally Posted by SteveVFX4
(Post 6899315)
^yeah, that's what I meant to say, behind the panel behind the rear passenger seat if you got a supercab or supercrew truck.
at least that's what I read on here. I have my code because I bought my truck new. |
the box is on the driver side behind the rear seat ...theirs two bolt and clips that hold the seat on ...do a search on the fourm and you can find pics and a better how to do
oops, yeah it is on the rear driver's side. Here is some info from a member's old post:
I found the code (with some help from my neighbor). It is behind the plastic trim that is in the rear corner on the driver's side of the cab. Down near the floor. Remove the door seal and pull the plastic trim away from the truck sheet metal. You might have to take off some more nearby trim to see better. With a flash light I could see the 5 digits, they were even right side up when looking from the outside. The numbers were on the right side (towards the tail gate) about in the middle of the computer. The computer has the word Siemans on it. |
