Help!!!! How to ID 360 vs.390
Hi guys,
I am going to look at a 75 F350 1 ton, and the guy says he was told it has a 390 engine. Some years back, I had several 1 tons, a 74, which I bought new with a 360, a 76 which came with a 360 (later put a 390 in it), etc. Seems I was told at one time that they could be distinguished by the water inlet housing. Don't know. So, I figure there are a lot of you Ford experts on here, and undoubtedly you can tell me what to look for in order to readily determine which engine it is. I will say I was very dissappointed with every 360 I ever had, although the 390 was a good engine. Any help would be greatly appreciated Thanks |
Only way to tell is stroke:
360 = 3.50, 390 = 3.784 IIRC a '75 390 in a truck might have been available with a 4bbl. If it's an original engine you can post the vin or data plate info for a read. As far as the water inlet housing they are all the same on FE motors. 351m vs. 351w have different water inlet housings, so that might be where that came from. There was a recent post I'll try to find from another source. |
I'd count on it being a 360, they somehow all become 390s on sale day since you can't tell any difference by sight. The 360 and 390 are the same block with the 1/4" difference in stroke as posted.
John :-X06 |
Pull #1 spark plug out and have a wooden dowl with you about 8" long smll enough to go thru the spark pluh hole and not catch on the sides...Bring #1 up to TDC (Top dead Center) drop the dowl in the hole and mark it at the plug hole.... and I believe #4 at this time is down at BDC...Pull that plug and repeat with the dowl in the spark plug hole (dont rotate the engine) and mark the dowl again....as you did on #1..
3.5" will tell you it has a 360 stroke and 3 3/4" will tell you it has a 390 stroke !! So many things have been changed by there owners or Mechanics over the years you cant tell by anyone thing from the outside.. ~Russ |
I dont recall 390's ever coming in a 4x4??
~Russ |
Originally Posted by RapidRuss
(Post 6831616)
~Russ
Originally Posted by UTfball68
(Post 6831683)
They did, but you'd have to ask Bill about the last year it was offered in a 4x4...seeing as I can't remember what exact year they stopped putting them in. I want to say it's somewhere in the 72-73 range. It would make sense to quit putting them in with a body style change...but as we all know, Ford had a tendancy of throwing leftover parts in the next model year. For how many times Bill has posted it, I can't believe I can't remember what year the 390 stopped going into 4x4's.
4x4 F-series in the 70's ONLY got the 360. At least, 73-79, that is, that I know of.
So, if it's a 4x4, and a 75, and it's the original engine, it's definitely not a 390 ;) The only way to tell is to measure the stroke. |
(Post 6832029)
But there would be a helluva lot more swapped in if it's a 4x4 since the first year for a 350 4x4 was 79...
So it COULD have a 390. But doesn't really matter. Measure the stroke :-X14 |
Thanks to all of you guys for taking time to reply. And you are right, on sale day, more often than not, somehow the 360 magically turns into a 390! Have no way of knowing if the engine has ever been swapped, although I agree, in 33 years, most likely. Doubt it's original. And yes, it is just a conventional 2wd 1 ton. Wish it was a 4wd, though. I'll take a wooden dowel along and check the stroke, as was outlined. Once again, thanks for everyone's input.
Sincerely, John |
Originally Posted by 85e150six4mtod
(Post 6830308)
360 = 3.50, 390 = 3.784 IIRC a '75 390 in a truck might have been available with a 4bbl. If it's an original engine you can post the vin or data plate info for a read. As far as the water inlet housing they are all the same on FE motors. 351m vs. 351w have different water inlet housings, so that might be where that came from. There was a recent post I'll try to find from another source. Tim |
No 390's were ever factory installed in any 4WD.
1965/76 4WD engine availability. 1965/67 = 352 / 240 & 300 I-6 1968/74 = 360 / 240 & 300 I-6 1975/76 = 360 / 300 I-6. ------------------------ There is no way to tell by looking at any FE engine to determine what size it is. Externally: 1958/64, they all look the same. Externally: 1965/76, they all look the same. 1958/64's have rounded valve covers with no oil cap holes, and an oil fill pipe. 1965/76's have pent roof shaped valve covers with a hole in each. ---------------------------------------------------------------- The 4th digit of the VIN is the engine code. 1965/76 F100/350 1965: D = 352 2V 1966/67: Y = 352 2V. 1968/73: H = 390 2V / Y = 360 2V 1974/76: H = 390 2V / M = 390 4V / Y = 360 2V |
