Help!!!! How to ID 360 vs.390 - Ford Truck Enthusiasts Forums
Old 11-30-2008, 11:33 PM
R202INT R202INT is offline
R202INT is starting off with a positive reputation.
Hi guys,
I am going to look at a 75 F350 1 ton, and the guy says he was told it has a 390 engine. Some years back, I had several 1 tons, a 74, which I bought new with a 360, a 76 which came with a 360 (later put a 390 in it), etc. Seems I was told at one time that they could be distinguished by the water inlet housing. Don't know. So, I figure there are a lot of you Ford experts on here, and undoubtedly you can tell me what to look for in order to readily determine which engine it is. I will say I was very dissappointed with every 360 I ever had, although the 390 was a good engine. Any help would be greatly appreciated
Thanks
Old 12-01-2008, 12:48 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Only way to tell is stroke:
360 = 3.50,
390 = 3.784
IIRC a '75 390 in a truck might have been available with a 4bbl.
If it's an original engine you can post the vin or data plate info for a read.
As far as the water inlet housing they are all the same on FE motors.
351m vs. 351w have different water inlet housings, so that might be where that came from.
There was a recent post I'll try to find from another source.
Old 12-01-2008, 06:22 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
I'd count on it being a 360, they somehow all become 390s on sale day since you can't tell any difference by sight. The 360 and 390 are the same block with the 1/4" difference in stroke as posted.
John
Old 12-01-2008, 06:23 AM
RapidRuss's Avatar
RapidRuss RapidRuss is offline
FE "Freakin Expensive"
RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.
Pull #1 spark plug out and have a wooden dowl with you about 8" long smll enough to go thru the spark pluh hole and not catch on the sides...Bring #1 up to TDC (Top dead Center) drop the dowl in the hole and mark it at the plug hole.... and I believe #4 at this time is down at BDC...Pull that plug and repeat with the dowl in the spark plug hole (dont rotate the engine) and mark the dowl again....as you did on #1..
3.5" will tell you it has a 360 stroke and 3 3/4" will tell you it has a 390 stroke !!
So many things have been changed by there owners or Mechanics over the years you cant tell by anyone thing from the outside..
~Russ
Old 12-01-2008, 01:05 PM
RapidRuss's Avatar
I dont recall 390's ever coming in a 4x4??
~Russ
Old 12-01-2008, 02:11 PM
Rockstone's Avatar
Rockstone Rockstone is offline
Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.
Quote:
~Russ
Quote:
Originally Posted by UTfball68 View Post
They did, but you'd have to ask Bill about the last year it was offered in a 4x4...seeing as I can't remember what exact year they stopped putting them in. I want to say it's somewhere in the 72-73 range. It would make sense to quit putting them in with a body style change...but as we all know, Ford had a tendancy of throwing leftover parts in the next model year. For how many times Bill has posted it, I can't believe I can't remember what year the 390 stopped going into 4x4's.
I think I have to agree with the other Russ on this one. I seem to remember Bill saying Ford never installed the 390 into a 4x4. I do got a bad case of CRS though.
Old 12-01-2008, 02:37 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
4x4 F-series in the 70's ONLY got the 360. At least, 73-79, that is, that I know of.
So, if it's a 4x4, and a 75, and it's the original engine, it's definitely not a 390
The only way to tell is to measure the stroke.
Old 12-01-2008, 04:56 PM
Krewat's Avatar
But there would be a helluva lot more swapped in if it's a 4x4 since the first year for a 350 4x4 was 79...
VERY true - missed that part. It's an F350, so it can't be 4x4. From the factory, anyway.
So it COULD have a 390.
But doesn't really matter.
Measure the stroke
Old 12-01-2008, 07:38 PM
Thanks to all of you guys for taking time to reply. And you are right, on sale day, more often than not, somehow the 360 magically turns into a 390! Have no way of knowing if the engine has ever been swapped, although I agree, in 33 years, most likely. Doubt it's original. And yes, it is just a conventional 2wd 1 ton. Wish it was a 4wd, though. I'll take a wooden dowel along and check the stroke, as was outlined. Once again, thanks for everyone's input.
Sincerely,
John
Old 12-01-2008, 08:34 PM
dbossman dbossman is offline
dbossman is starting off with a positive reputation.
Quote:
360 = 3.50,
390 = 3.784
Actually, there is more than just one way. If its an automatic, you can pull the transmission flex plate cover, and look at the crankshaft flange. The 360 has a big half moon cut out of the flange. The 390 crank does not. The cutout was necessary to properly machine the 360 crank.
Tim
Old 12-02-2008, 05:18 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
No 390's were ever factory installed in any 4WD.
1965/76 4WD engine availability.
1965/67 = 352 / 240 & 300 I-6
1968/74 = 360 / 240 & 300 I-6
1975/76 = 360 / 300 I-6.
There is no way to tell by looking at any FE engine to determine what size it is.
Externally: 1958/64, they all look the same.
Externally: 1965/76, they all look the same.
1958/64's have rounded valve covers with no oil cap holes, and an oil fill pipe.
1965/76's have pent roof shaped valve covers with a hole in each.
The 4th digit of the VIN is the engine code.
1965/76 F100/350
1965: D = 352 2V
1966/67: Y = 352 2V.
1968/73: H = 390 2V / Y = 360 2V
1974/76: H = 390 2V / M = 390 4V / Y = 360 2V
Old 05-24-2014, 11:47 AM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
here's a how-to ID a 360/390 with pictures!
http://www.ford-trucks.com/forums/90...l#post13616693
Old 05-24-2014, 07:56 PM
Hhhm, 2008 thread, won't let me see page 2. Hhhm...
Building my 360 to a 390, need ideas mountain dewd 1973 - 1979 F-100 & Larger F-Series Trucks 9 12-02-2016 11:17 AM
Good the bad the 360 Bftford FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 03-15-2014 07:27 AM
360 to 390 Mounts 1956in1956 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 09-14-2013 12:51 PM
different oil filter mount on my FE's ??? supercabfreak FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 11-09-2011 09:09 PM
What can you make from a 390 TheTowingCowboy FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 31 07-03-2010 05:35 PM
Tags
360, 390, block, crank, crankshaft, difference, dowel, engine, ford, id, identification, stroke, strokes, truck, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
