rear shocks for truck with a lot weight
I carry a lot af tools etc. all the time my truck has the oem shocks on it and is level but it is probably time to put on some new rear shocks. I would like maybe a little lift. Any suggestions.
Eric 99 F150 4.6 sup cab 4x2 flr side |
Probably not gonna get any lift with a set of shocks. The guys in the f150 forum should be able to help lift wise. https://www.ford-trucks.com/forums/forum25/
For shocks: i like bilsteins lol |
What if I use leaf spring spacer blocks for lift ? How much do you think is ok so if I pull the weight out I will still be in tolerance and not risk having the drive shaft in the wrong place. I had a shaft come out on a 94 F150 and shred the teeth on it by lifting it like this and removing the weight.
Eric 99 F 150 Sup Cab 4x2 Flr Side 4.6 |
Bilstein are great shocks. I'd recommend a set of their heavy-duty shocks for your work truck, and don't look back. Instead of playing with lift, put on some helper springs that will let you carry the load without affecting your stock ride height and steering geometry (remember how you shredded that '94?). This is a work truck, not a toy, so keep it simple, and close to stock. If you can't find any parts from the forum sponsors, JC Whitney comes to mind as the ideal place to find helper springs.
I put a set of Monroe Gas Magnums on my truck and they seem to do all right. I've only ever carried one really heavy load, and that was sitting on the overload springs (almost frame snubbers), so I can't really say how they'd perform in daily work duty. |
Thanks I'm gonna look into that.
Eric 99 F 150 |
You might want to look into air bags. I know a guy at a trailer place that has installed a few. I put air shocks on my 86 F250 SC.
