Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Virginia Chapter Join Chapter, Leader: archtaan
  #1 (permalink)
Old 11-22-2008, 07:27 AM
SSG VA BEACH's Avatar
SSG VA BEACH SSG VA BEACH is offline
1999 Ford F-150
SSG VA BEACH is starting off with a positive reputation.
rear shocks for truck with a lot weight
I carry a lot af tools etc. all the time my truck has the oem shocks on it and is level but it is probably time to put on some new rear shocks. I would like maybe a little lift. Any suggestions.
Eric
99 F150 4.6 sup cab 4x2 flr side
  #2 (permalink)
Old 11-22-2008, 04:15 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3 STROKIN'IT7.3 is offline
Garage is empty, add now
STROKIN'IT7.3 has a very good reputation on FTE.STROKIN'IT7.3 has a very good reputation on FTE.STROKIN'IT7.3 has a very good reputation on FTE.
Probably not gonna get any lift with a set of shocks. The guys in the f150 forum should be able to help lift wise. http://www.ford-trucks.com/forums/forum25/
For shocks: i like bilsteins lol
__________________
WILL PAA #30
2001 F250 XLT Auto EC LB 4x4
THE DP Tuner, a few other goodies
1931 Model A 78-B "Wide Bed"
Join the Virginia Chapter!! http://www.ford-trucks.com/forums/forum147/
  #3 (permalink)
Old 11-23-2008, 07:44 AM
1999 Ford F-150
What if I use leaf spring spacer blocks for lift ? How much do you think is ok so if I pull the weight out I will still be in tolerance and not risk having the drive shaft in the wrong place. I had a shaft come out on a 94 F150 and shred the teeth on it by lifting it like this and removing the weight.
Eric
99 F 150 Sup Cab 4x2 Flr Side 4.6
  #4 (permalink)
Old 11-23-2008, 08:59 AM
BigBlue88 BigBlue88 is offline
BigBlue88 is starting off with a positive reputation.
Bilstein are great shocks. I'd recommend a set of their heavy-duty shocks for your work truck, and don't look back. Instead of playing with lift, put on some helper springs that will let you carry the load without affecting your stock ride height and steering geometry (remember how you shredded that '94?). This is a work truck, not a toy, so keep it simple, and close to stock. If you can't find any parts from the forum sponsors, JC Whitney comes to mind as the ideal place to find helper springs.
I put a set of Monroe Gas Magnums on my truck and they seem to do all right. I've only ever carried one really heavy load, and that was sitting on the overload springs (almost frame snubbers), so I can't really say how they'd perform in daily work duty.
__________________
1976 F-100 XLT Ranger (home improvement mule)
- 300/T-18/3.00, manual brakes & busted power steering
- Offy DP, QJet, EFI manifolds, Dynomax exhaust
2008 Chrysler 300
2005 Chevrolet Impala
  #5 (permalink)
Old 11-23-2008, 09:17 AM
1999 Ford F-150
Thanks I'm gonna look into that.
Eric
99 F 150
  #6 (permalink)
Old 11-23-2008, 12:44 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
You might want to look into air bags. I know a guy at a trailer place that has installed a few. I put air shocks on my 86 F250 SC.
__________________
[/SIGPIC]George 54 F100, 78 F150, 79 F150, 86 F250, 87 F250 Member #5 Boy you ain't Right Club Official Slackmaster #15
Tags
1999, 78, f150, load, lot, parts, rear, shocks, struts, trucks, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
