Speaker Wire ID - Positive/Negative, and troubleshoot
I just purchased a 1994 Ford Explorer. I'm replacing the deck and four speakers (door speakers).
I need to ID the stock positive/negative speaker wires. I have white with green stripe and green with orange stripe (I just checked the right front door so the others may be different). Also, I replaced the deck and now no speakers work at all. There is no sound. I checked and there is power going through the speaker wires from the deck, through the first harness (black harness, 8 wires, I soldered to the speaker wires from the deck). That harness connects to another harness and the wires are then wrapped (stock wiring harnesses). Can anyone tell me where that goes and then must split off to the speakers. I have power from the deck to where it plugs into the harness and no power at the speakers. Thanks much!!! |
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Red or Black Car Radio Illumination Wire: Orange/Black Car Stereo Dimmer Wire: Light Blue/Red Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: Blue Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Pink/Light Green Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Pink/Light Green Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Black/White |
Thank You ! ! ! !
