Speaker Wire ID - Positive/Negative, and troubleshoot - Ford Truck Enthusiasts Forums
Old 09-26-2008, 05:52 PM
Ace!'s Avatar
Ace! Ace! is offline
Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.
I just purchased a 1994 Ford Explorer. I'm replacing the deck and four speakers (door speakers).
I need to ID the stock positive/negative speaker wires. I have white with green stripe and green with orange stripe (I just checked the right front door so the others may be different).
Also, I replaced the deck and now no speakers work at all. There is no sound. I checked and there is power going through the speaker wires from the deck, through the first harness (black harness, 8 wires, I soldered to the speaker wires from the deck). That harness connects to another harness and the wires are then wrapped (stock wiring harnesses). Can anyone tell me where that goes and then must split off to the speakers. I have power from the deck to where it plugs into the harness and no power at the speakers.
Thanks much!!!
Old 09-27-2008, 02:19 PM
Truckin4life Truckin4life is offline
Street Queen to the extr3m3
Truckin4life has a great reputation on FTE.Truckin4life has a great reputation on FTE.Truckin4life has a great reputation on FTE.Truckin4life has a great reputation on FTE.Truckin4life has a great reputation on FTE.
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Pink/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Black/White
Old 09-27-2008, 02:23 PM
Ace!'s Avatar
Thank You ! ! ! !
Running New Speaker Wire jamestokelly Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 12 05-09-2016 06:02 AM
Aftermarket deck and stock speakers Krazee Matt Excursion - King of SUVs 4 04-27-2014 09:38 AM
keeping factory head, installing aftermarket amps- factory speaker wire routing!? hasteranger Excursion - King of SUVs 13 04-12-2012 06:58 AM
Installing New Speakers - 04 Crew Lariat - positive/negative wire colors??? SturgeonHunter 1999 to 2016 Super Duty 3 05-07-2010 04:05 PM
Plug on Stock Speakers 1957F100 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 08-16-2007 10:06 AM
Tags
black, cords, deck, explorer, f150, ford, green, negative, positive, speaker, speakers, white, wire, wires, yellow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
