'99 Ford F150 Heater Problem
As we approch winter I checked out my heater to find it does not work!!!!!!!!!!! :-hair
I drove my truck into town and open the hood to check the two heater hoses. Both hoses were hot so I can rule out heater core being blocked. :) When I arrived home, I turned off my engine and listen next to the vent box to listen for the door flap to open and close when I would rotate cold to hot on my temp switch. That too works! :) :-huh The only thing I do not understand is why my AC Compressor is still running after I rotate the switch to HOT and go to defrost yet no heat only cold air from the AC (again with the temp control to full heat RED). Now since I am confused .. I am wondering if the temp control switch is bad? Seems after you pass the mid point from cold to hot the switch would deselect the ac compressor from starting. :confused: Anyone have this problem or going through the same pains?? .. Oh! will will be painfull come winter ... Nebraska areas are sometimes -4 + with high winds. I do not foresee me being in my truck if it doesnt have any heat .... LOL! |
See the FAQs above...
Steve |
Originally Posted by projectSHO89
(Post 6552094)
Steve Steve, I looked but do not understand what you want me to see in the FAQs ??? |
Originally Posted by TexAcoon
(Post 6612895)
Steve,
