'99 Ford F150 Heater Problem
Old 09-13-2008, 11:43 PM
TexAcoon's Avatar
TexAcoon
TexAcoon is offline
As we approch winter I checked out my heater to find it does not work!!!!!!!!!!!
I drove my truck into town and open the hood to check the two heater hoses. Both hoses were hot so I can rule out heater core being blocked.
When I arrived home, I turned off my engine and listen next to the vent box to listen for the door flap to open and close when I would rotate cold to hot on my temp switch. That too works!
The only thing I do not understand is why my AC Compressor is still running after I rotate the switch to HOT and go to defrost yet no heat only cold air from the AC (again with the temp control to full heat RED).
Now since I am confused .. I am wondering if the temp control switch is bad? Seems after you pass the mid point from cold to hot the switch would deselect the ac compressor from starting.
Anyone have this problem or going through the same pains?? .. Oh! will will be painfull come winter ... Nebraska areas are sometimes -4 + with high winds. I do not foresee me being in my truck if it doesnt have any heat .... LOL!
Old 09-16-2008, 07:03 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
See the FAQs above...
Steve
Old 10-03-2008, 09:39 PM
TexAcoon's Avatar
TexAcoon
TexAcoon is offline
Steve
Steve,
I looked but do not understand what you want me to see in the FAQs ???
Old 10-03-2008, 10:09 PM
projectSHO89
Originally Posted by TexAcoon
Steve,
..very last section answers your question...
krisinwa
2004 - 2008 F150
20
11-08-2015 01:11 PM
superman7928
01-30-2015 03:08 PM
dspencer40
1997-2006 Expedition & Navigator
01-01-2015 08:19 AM
Jeff West
02-18-2014 09:55 PM
64F260
02-13-2009 01:00 PM
Quick Reply: '99 Ford F150 Heater Problem
