P0307 cylinder 7 misfire
Hi all,
hope everyone is good and enjoying there Ex, I recently got back from a short road trip and i felt the Ex sort of stumble a bit when im stopped and it would run fine once im driving. One of my buddies plugged in his ODB code finder and it came up with this code P0307 cylinder 7 misfire what does this mean I am taking the Ex to the dealer on monday so they can service it and fix the problem. My question is what should i be expecting to pay and how much work will this be i am not mechanicaly inclined but i am a member of the best forum there is and the best group of people i ever met online with a wealth of knowledge. |
i had the same thing happen a couple weeks ago. same code and cyl. i didn't trust the cheapo scanner so i went to ford and for $127, THEY SAID THE SAME THING AS THE CHEAPO SCANNER. well i took the truck back and had them unplug the coil and injector for that cyl. i ordered a brand new motorcraft coil from ebay for $35(an extra too) and in 5 minutes i repaired it. i just cleared the code and no problems since.
Originally Posted by dreyes212
(Post 6272895)
Hi all,
hope everyone is good and enjoying there Ex, I recently got back from a short road trip and i felt the Ex sort of stumble a bit when im stopped and it would run fine once im driving. One of my buddies plugged in his ODB code finder and it came up with this code P0307 cylinder 7 misfire what does this mean Clear the code and then swap the COP's on the number 7 and number 6 cylinder to see if you get a P0306 code: cylinder 6 misfire. If you do, then you know you have a bad coil. Just buy a replacement COP and put the new one on. Don't spend hundreds of dollars at a dealership for something you can do in about 7 minutes. It's possible you have a bad plug in that cylinder, but it's more likely a bad coil. Stewart |
It's EXTREMELY easy to pull a COP and replace or swap it with another one.
Ignition Coil—On Plug <META content="Ignition Coil—On Plug" name=tps_proctitle>Removal
There ya go. Stewart |
YOU GUYS ROCK!!!!:-headbang
Thanks for the help Stewart i appriciate the pictures and steps. |
(Post 6273374)
Thanks for the help Stewart i appriciate the pictures and steps. Since you said you weren't mechanically inclined, I figured the pictures would help. That's also why I added two minutes to Racer's time estimate! ;) It really is that easy. Stewart PS - Do you know which cylinder is number 7? As you look at the engine from the front of the truck with the hood open, starting with the passenger side, front to back, you have cylinder 1, 2, 3, 4, and 5. Then on the drivers side, front to back, it's number 6, 7, 8, 9, and 10. |
Originally Posted by Stewart_H
(Post 6273376)
No prob.
Since you said you weren't mechanically inclined, I figured the pictures would help. That's also why I added two minutes to Racer's time estimate! ;) It really is that easy. Stewart PS - Do you know which cylinder is number 7? As you look at the engine from the front of the truck with the hood open, starting with the passenger side, front to back, you have cylinder 1, 2, 3, 4, and 5. Then on the drivers side, front to back, it's number 6, 7, 8, 9, and 10. thanks you could have not made it any easier... |
Yea, #7 is the second one back on the drivers side!!!.. Super easy to change out. If you are getting a P0307 it is #7 COP. If you haven't changed the plugs yet, do so!!
(Post 6273347)
Sounds like you have a bad COP (Coil On Plug) that fires intermittently.
