P0307 cylinder 7 misfire - Ford Truck Enthusiasts Forums
Old 06-20-2008, 09:11 PM
dreyes212's Avatar
dreyes212 dreyes212 is offline
dreyes212 is gaining momentum as a positive member of FTE.
Unhappy P0307 cylinder 7 misfire
Hi all,
hope everyone is good and enjoying there Ex, I recently got back from a short road trip and i felt the Ex sort of stumble a bit when im stopped and it would run fine once im driving. One of my buddies plugged in his ODB code finder and it came up with this code P0307 cylinder 7 misfire what does this mean I am taking the Ex to the dealer on monday so they can service it and fix the problem. My question is what should i be expecting to pay and how much work will this be i am not mechanicaly inclined but i am a member of the best forum there is and the best group of people i ever met online with a wealth of knowledge.
Old 06-21-2008, 12:54 AM
RACERX7775's Avatar
RACERX7775 RACERX7775 is offline
PROFESSIONAL KNOW-IT-ALL
RACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to behold
i had the same thing happen a couple weeks ago. same code and cyl. i didn't trust the cheapo scanner so i went to ford and for $127, THEY SAID THE SAME THING AS THE CHEAPO SCANNER. well i took the truck back and had them unplug the coil and injector for that cyl. i ordered a brand new motorcraft coil from ebay for $35(an extra too) and in 5 minutes i repaired it. i just cleared the code and no problems since.
Old 06-21-2008, 02:00 AM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Originally Posted by dreyes212 View Post
Hi all,
Sounds like you have a bad COP (Coil On Plug) that fires intermittently.
Clear the code and then swap the COP's on the number 7 and number 6 cylinder to see if you get a P0306 code: cylinder 6 misfire. If you do, then you know you have a bad coil. Just buy a replacement COP and put the new one on. Don't spend hundreds of dollars at a dealership for something you can do in about 7 minutes.
It's possible you have a bad plug in that cylinder, but it's more likely a bad coil.
Stewart
Old 06-21-2008, 02:15 AM
Stewart_H's Avatar
It's EXTREMELY easy to pull a COP and replace or swap it with another one.
Ignition Coil—On Plug
<META content="Ignition Coil—On Plug" name=tps_proctitle>Removal
  1. Disconnect the wiring at the coil.
  1. Remove the bolt and the coil.
Installation
  1. NOTE: Remove any foreign material from spark plug wells with compressed air.
    To install, reverse the removal procedure.
There ya go.
Stewart
Old 06-21-2008, 02:37 AM
dreyes212's Avatar
YOU GUYS ROCK!!!!
Thanks for the help Stewart i appriciate the pictures and steps.
Old 06-21-2008, 02:40 AM
Stewart_H's Avatar
YOU GUYS ROCK!!!!
No prob.
Since you said you weren't mechanically inclined, I figured the pictures would help. That's also why I added two minutes to Racer's time estimate!
It really is that easy.
Stewart
PS - Do you know which cylinder is number 7? As you look at the engine from the front of the truck with the hood open, starting with the passenger side, front to back, you have cylinder 1, 2, 3, 4, and 5.
Then on the drivers side, front to back, it's number 6, 7, 8, 9, and 10.
Old 06-21-2008, 04:43 AM
dreyes212's Avatar
Quote:
Originally Posted by Stewart_H View Post
No prob.
Stewart
thanks you could have not made it any easier...
Old 06-21-2008, 07:00 PM
rlh68050's Avatar
rlh68050 rlh68050 is offline
rlh68050 is gaining momentum as a positive member of FTE.rlh68050 is gaining momentum as a positive member of FTE.
Yea, #7 is the second one back on the drivers side!!!.. Super easy to change out. If you are getting a P0307 it is #7 COP. If you haven't changed the plugs yet, do so!!
Old 06-21-2008, 07:23 PM
1's Avatar
1 1 is offline
1 is gaining momentum as a positive member of FTE.1 is gaining momentum as a positive member of FTE.
Stewart
I agree 100% with this post.
01 f250 loses power and runs rough oliebeme 1999 - 2003 7.3L Power Stroke Diesel 5 03-21-2015 10:22 AM
Help with misfire! VelleLS1 1999 to 2016 Super Duty 10 11-28-2013 06:56 PM
OBDII code questions? Trevor.801 Excursion - King of SUVs 3 07-11-2013 11:10 AM
Code P0307 happeetxn 1997-2006 Expedition & Navigator 8 10-02-2012 10:20 AM
03 Expy 5.4 code P0307 RedHorse1 1997-2006 Expedition & Navigator 4 11-09-2010 01:55 PM
Tags
2001, 50, 740i, bad, bmw, code, cylinder, engine, f250, ford, misfire, no, p0306, p0307, stumble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
