Same here on the fuel filter. I took me and a buddy several hours of: "Ok, I'll twist this while you push here and gently tap it in the other direction" type nonsense interspersed with checking several manuals and the internet because we figured we had to be doing something wrong but couldn't figure out what.
Got my new infinity door speakers in the mail today. Installed them this afternoon, sounding pretty good!
Fuel filter only took me about a half hour or so to remove and replace. Was kinda a PITA but I don't see how it could take hours, like it does for most people lol.
Replaced the rear driveshaft rear u-joint because I discovered there were two cups with no needle bearings. Just a little loose! Ordered a new carrier bearing, and the other two u-joints so I can rebuild the entire shaft.
While doing this, I noticed that the PO used u-bolts that were a tad too short when replacing the springs. Also noticed that when he did the rear rubber brake line, he didn't re-install the vent/hold down bolt. Ordered that stuff too. |
Originally Posted by minnesotafisherman
(Post 11894769)
Originally Posted by RIKIL
(Post 11894891)
Beer & beer
Today I replaced the fuel filter, PCV valve, and also picked up a replacement front tank (my old one was removed due to rot.)
Ricky welcome to FTE & keep up the good work guys
RE: fuel filter removal. The tools dont fully disengage the filter like they should so they have to be "worked" I should just cut the tubing and replace the filter with one that just uses hose clamps next time, It would be a WHOLE lot easier.
Originally Posted by Plain Jane
(Post 11892717)
Saves a ton of time.. |
purchased a new rear plastic tank and hardware for my 2wd off of broncograveyard. started fabbing up my tail pipes with my HD dresser mufflers for tips.
Started putting the rear tank onto my truck...
Well what are you waiting for Wes, lol
Originally Posted by GIGGER
(Post 11899038)
Seems the pump can get power to it, but doesn't actually try to "Pump"...Just, a "Click" and that's it.. Coming from the pump, so it isn't a relay, etc.... |
Got the emissions inspection done. Passed with flying colors! Finally, fully legal. :)
